ARB bumper for GU - R5500
DMH
Full Name: Tejan Pillay
Nickname: Tej
Home Town: durban
Current 4x4: 95 Patrol SGL 4.2D,
02 Hardbody 3L TD
Home Language: english
Has thanked: 15 times
Post by DMH »
Just saw the ad on gumtree chaps
http://www.gumtree.co.za/view.html?adId ... paign=bolt
He's in Jhb
Been thanked: 724 times
Re: ARB bumper for GU - R5500
I would be careful in dealings with this guy. Out of morbid curiosity, I e-mailed and got a response from "Bush Armor Off road".
My word of caution stems from this thread in the Community Forum:
http://www.4x4community.co.za/forum/sho ... p?t=214376
Ian
Has thanked: 60 times
Been thanked: 255 times
The add states that it will fit any Patrol from 1999 to 2010.
I can assure you it won't. Since the 2005 facelift the position of the mountings changed. The pictures are of the ARB bumpers for Patrols of 2004 and prior.
Tej, in case you were considering it for your car, it won't fit the GQ either
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post by JoshJ »
I have to agree with Alex, pre 05 bumper does not fit properly on a post 05 bumper. The nose of a post05 is longer then a pre 05. Not chassis wise but fender bumper, grill lights make the nose a tad longer. This causes the bumper not to fit properly. Thats why i am driving with a 15K bumper and not a 6K. Damm pity actually :lol:
Being alive is a Blessing!!
Joshua
Spoke to the man its on a 99 4.5 there is space to cut out the grill on a 2005 up
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Post by Clem »
Tinus - not following. Will it fit my 2013 GRX?
Jip it will
Clem
Nickname: Clem
Post by Clem »
Thanks Tinus. I will buy it then.
Clem wrote:Tinus - not following. Will it fit my 2013 GRX?
Clem, I had an ARB bumper on my 2004 Patrol that looked exactly like this one (look at my Avatar).
Then I decided I do not like it anymore, it had no place for the fog lights and was not doing my approach angle any good.
So to improve my approach angle and fit fog mist lights, I opted for a custom built front bumper instead (BG Autofit).
Now my approach angle is only limited by my chassis. Having a 2" body lift also helped in this regard.
At the same time another forum member (DawidT) with a post 2005 facelift Patrol wanted my bumper.
To get the pre-2005 ARB bumper to fit his face-lift Patrol required a lot of cutting and refitting and more cutting, until it fitted his grill. Ben at BG Auto fit can tell you that this was time consuming to do.
I therefore cannot agree with Tinus, but if you have the capabilities to cut the steel and the patience for some trial and error refitting it again, then by all means go ahead.
Clem
Nickname: Clem
Post by Clem »
Thanks Alex. I'm going to let it go. There are other options out there. Can you post a pic of your setup sometime?
