urgently need timing gear cover
- Full Name: Steyn
- Nickname: Andre
- Home Town: Rustenburg
- Current 4x4: 99 Nissan Patrol Y61 4.2 Turbo intercooled Station wagon or Nissan patrol 4.2tdi pick up and now wifey's 2007 4.8 grx added to the family
- Been thanked: 11 times
Evening gents I urgently need either a new or good condition timing gear cover with the vacuum pump space as mine is not on the altenator. I need to get the trol going again before Tuesday this week. I'll even buy new if I know it'll be here fast. I'm in Rustenburg.
- Full Name: Steyn
- Nickname: Andre
Re: urgently need timing gear cover
Forgot to mention the reason for replacement, its all due to the severe pitting in the water pump housing. So anyone know where I can get one quick? The current ud 40 moters might also fit if the vacuum pump sits under the fuel pump and not on the altenator. I'm also looking for a cast td42t exhaust manifold trying my luck to find one.
Jisssssssss Andre. Het jy met David Volschenk gepraat ? Hy behoort te hê. Anders kan jy ook One Tonner spres probeer
David is in Bela-Bela en 1-tonner is in Pta - Wes
- Full Name: Steyn
- Nickname: Andre
Ek Sal bietjie more vir David kontak om te hoor of hy nie dalk vir my ñ ander een het nie, al wat my worry is die spasie vir die vacuum pomp ek vermoed baie van die wat david dalk het sit ook moontlik op die altenater en nie onder die dieselpomp nie. Uiteinde is ongelukkig dan nou die agente teen R3083,00! Maar moet ook bysê hy het darem ñ goeie 421200km gehou. Moes eintlik al vroeer die issue aangespreek het maar dis ñ nare job om die spul uit te kry.
- Been thanked: 1038 times
Andre praat ook met Louis (Aries66), ek weet hy het stukke van 'n enjin by hom?
- Been thanked: 473 times
Andre, Its only the silver top TD42's that have the vacuum pump on the alternator, and those motors are VERY scarce!! its a very good chance that the motors with David will work.
As far as I know the TB42 exhaust manifold is identical to the TD42 manifold, BUT I'm not sure about the TD42T. maybe a minor modification or flange can be made to mount the turbo onto
- Full Name: Steyn
- Nickname: Andre
Stroke of good luck this morning came across 2 stripped td42 ud 40 moters at a Enginering this morning apparently blocks cracked but al else is good. So gents anyone looking for some other td42t bits,the moters are complete except for the blocks and pistons and now of course the one timing cover. They are basically asking half the price of new parts as these moters had +-60000-80000km on them so all still very new.
