Is this Front Runner Jerry Can holder Safe?
vanhack
Full Name: Siddharth Patel
Nickname: Sid
Home Town: Dubai, UAE
Current 4x4: Y61 LWB Patrol TB48E, Auto
Has thanked: 36 times
Been thanked: 24 times
Post by vanhack »
Hi, I have inherited a double jerry can holder, and have mounted 2 jerry cans on the roof rack, I see that Front Runner have evolved their design of the holder since this was purchased about 6-7 years ago, can anyone let me know if the holder is safe and does not come apart over bumby terrain.
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Re: Is this Front Runner Jerry Can holder Safe?
Post by Clem »
I have two made to an almost identical design out of aluminium and with the same type of canopy clip. I used them for years across some of the worst terrain anywhere in Africa and I never had a single problem. I very much doubt that you will have a problem.
vanhack
Nickname: Sid
Post by vanhack »
Thanks for the reply, I will use them this weekend. First time driving with jerries on the roof rack, bit nervous with that idea.
Clem
Nickname: Clem
Post by Clem »
Two jerry cans on the roof of a Patrol should really not be an issue, unless you have a lot of other weight up there. The other thing that has an effect on the centre of gravity is if the vehicle has been lifted.
Those brakets are good....just make sure that the braket going over both cans are the correct way around. There is a little piece that clips in to the strap holding the cans down ....also make sure straps go over openers like on the pic....i drive with 6 cans on the roof never had a problem :thumbup:
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Post by Grant »
Sid,
They work very well but as said make sure that all bolts are tight. For safety I also use a ratchet strap around both cans.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post by JoshJ »
+1 on what everyone said. At least you dont have to worry about trees knocking them off :lol:
strap them in and enjoy your weekend :thumbup:
Being alive is a Blessing!!
Joshua
vanhack
Nickname: Sid
Post by vanhack »
Just for others to know, the jerry can holder held up well that weekend. only issue was that the pins kept rattling out of the openings, which is added locking mechanism.
Are you talking about the pins on the cans themselfs?
Clem
Nickname: Clem
Post by Clem »
The pins may well rattle out if you don't use them correctly. The pin should have one end flattened and the other end should have a small hole through it. You need to put a ring (usually supplied with the tin) or other retention device through the hole. Incidentally, I only buy genuine German TUV marked cans. The other stuff is usually not as good and I have had Chinese made cans that weren't worth the cost of the paint on them! Also, keep a few of the rubber gaskets handy as they do eventually wear out.
Another tip - good funnel with a good filter in it (genuine mutton cloth - not the cheesecloth that is usually sold as mutton cloth - is a good option) is advisable. That way any dirt or debris in your cans will not end up in your tank.
