Sub Tank problem
JohnST
Full Name: John Greeff
Nickname: John
Current 4x4: 2001 Nissan Patrol 4500
Sub Tank problem
Post by JohnST »
Howzit guys
Nice forum. :thumbup:
I got my patrol (2001 4500 GRX) a while ago.
Absolutely love her.
Upgraded suspension and done proper service (everything I could)
What needs to be done is altinator bearing are starting to sing so will recon this month and then...
The sub tank light has been on since I got her and it's not working.
Tested there is power going to the switch. Replaced switch with original nissan new one, still no luck so now I need some advice...
Please :think:
Re: Sub Tank problem
Welcome here
:salute:
There is a lot of info on the subtank issue here also drawings etc just search for sub tank on left top and you will find it :thumbup:
Have a look at your sub tank control box ....sometimes there is a issue with one resistor
Hier is deel van die Manual vir die sub-tank.
Subtank.pdf
(405.14 KiB) Downloaded 420 times
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Post by SCUBA Patrol »
John,
Try and disconnect the battery for the evening for the engine management to reset. 90% of the time it will sort the sub-tank problems out.
Phillip
Phillip
2006 3l with MADMAN
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Post by Marino4x4 »
Jip
First try the disconnecting. Sorted my problem out. Also had the light that stayed on.
Welcome here and do an introduction. :welcomewave: :welcomewave:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 »
Jip
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Post by Clem »
Herrie wrote:Hier is deel van die Manual vir die sub-tank.
That document is very useful!
Tinus.... I like your left and right directions... do you get lost sometimes??...... :rolling: :rolling: :rolling: ( Just kidding ).....just search for sub tank on left top and you will find it....... JohnST, try the search on the top RIGHT rather :thumbup: :thumbup:
Has thanked: 1130 times
Been thanked: 1044 times
Cedric, Tinus never gets lost.
People who try and follow his directions though, that's a different story...
:doh:
:pray:
:think:
:redface:
hahahahahaha.... If he was in Durban he could say that ...." you just hook a left there right "..... :rolling: :rolling:
