Ironman Winch switch of Death by Frustration
Tjaart
Nickname: TJ
Current 4x4: Patrol 4500 GRX
2000
Post by Tjaart »
I got a new Ironman 12000pd winch, What a machine. It is strong and reliable....But only if the donnerse little switch they install under the bonnet works :chainsaw: :steamingears: .
I was at the Olifants Challenge over the weekend and had to use the winch to recover other stuck 4x4's, but that F#$)#@#NG switch didn't work. Apparently, it is part of the installation requirement and is installed as a safety device. This winch comes with a remote control. :think: . Why in the world? You should in your vehicle when winching, should something go wrong. This remote can be activated by mistake in the cubbyhole or center console. So when you want to winch, you have to open the bonnet, :thumbup: , put in the "key" - plastic - turn it to the "on" position, and winch away. NO. because the damned donnerse ding werk nie!!! :helpsos: . So I stripped it out and connected the wires direct to the battery, took the remote apart, moered away the battery, and now only work the remote with the cable supplied with the winch. And works like a charm. Once I did this I help recover all the guys getting stuck in the deep water, where the Patrol got through, no problem!! :thumbup:
THE BRAVE
says
Aut PATROL aut nihil
Aut vincere aut mori
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Monument Park
Current 4x4: 2013 FJ Cruiser
Been thanked: 7 times
Re: Ironman Winch switch of Death by Frustration
Post by Abri Hoffman »
Nothing like a bit of sweat, swearing and boeremachanic to make these things work. :thumbup:
2013 FJ Cruiser
"Jack Russel"
Glenric
Full Name: Glenn Kichenbrand
Nickname: Glenric
Home Town: Springs
Current 4x4: Nissan Hardbody D/C 3,3 V6 4x4
Post by Glenric »
Just bought the same winch but addressed your comments prior to instillation.
CHRISTO DU PLESSIS
Suspension Solutions
IRONMAN S.A
Tel : +27 (0) 11 634 7600
Fax : +27 (0) 11 493 3132
christo@suspensionsolutions.co.za
asked that you get intouch with him so that he can facilitate a factory/supplier upgrade on the wireless unit. :clap:
