Diesel Patrol 90s
- Newbie
- Full Name: Norman Jooste
- Nickname: Norman
- Current 4x4: Toyota Landcruser Picky up
- Home Language: AFR
Diesel Patrol 90s
Dag Manne
Eks opsoek na n diesel patrol vir die prysklas van so R40000.
My hande is nie rond nie so n bietjie werk gaan my nou nie pla nie.
As enige imand van iets weet laat my asb weet.
0724376113
norman@aventra.co.za
Ek wil hom ook graag turbo sa as imand dalk vir my bietjie raad het sal ek dit waardeer.
Groete.
0724376113
Groete.
Re: Diesel Patrol 90s
Finding a diesel Patrol for R40K will take a bit of time, cause they don't come up too often. In that price range it will be a GQ, or maybe an old Safari with the RD28 motor.
Turbo'ing a diesel is also not just a matter of fitting the turbo. The older TD42's and RD28's ( I may be wrong on the RD28 ) were never turbo'ed and will probably have very high mileage and will need to be opened up and possibly new rings and bearings fitted.
The type of turbo also plays a huge roll in how your motor will perform. You need to get the A/R ratio correct for the size of motor. Safari do an aftermarket water cooled turbo for the Patrol/Safari, but these aren't cheap. You will need a good intercooler too. You could easily spend a little fortune to do the conversion.
Lets hear what the other guys have to say.
Diddo on what Cedric said ...there is a 2.8 available in the market place. ....a good gq diesel will set you back about 60k and a gu around 120k not easy to find but be pasient they do come arround ....converting a petrol to a diesel is very easy gearboxes diffs ect is the same for tb42 and td 42t a good rebuild td42t is gonna set you back about 35k
We are busy with 2 at the moment
hope this helps
welcome here
hope this helps
welcome here
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
I had the previlage to be taken for a ride in Michaels 4.2TD. That thing pulls like mad. He might be a good guy to compare notes with when it comes to the turbo bit. His engine was not a turbo 4.2. He made it a turbo 4.2 With all the correct inners. Those 4.2's are awsome.
Cedric, know I know why you are so in love with your maiden.
Being alive is a Blessing!!
Joshua
Joshua
Josh.... there is nothing nicer than pulling off and hearing the turbo spool up, and then change gears and have the whistle of the gasses dumping into the exhaust between gear changes...... its so nice it like being a teenager and looking at those naughty magazines for the first time.......
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 193 times
- Been thanked: 275 times
Yep, at that price you are looking at a Safari...
http://patrol4x4.co.za/viewtopic.php?f=65&t=5267
and that looks like a sweet ride !!
BTW... just a slight correction .... Michaels TD42 motor did have a turbo on with water to air intercooler on. He converted it to air to air intercooler, but the plumbing was all there already.
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 719 times
Norman,
The Safari linked to by OffroadBiker (Dirk) is still there - I drove past the dealership again this morning.
As mentioned, I've not had a lot of a chance to go and get details on it yet, but I can make a plan to stop by there this evening if you're interested.
Let me know.
Ian
Let me know.
Ian
- Been thanked: 432 times
Well yes, it was a turbo conversion done by Safari I think. The problem was it was just bolted on and it didnt last.ricster wrote:BTW... just a slight correction .... Michaels TD42 motor did have a turbo on with water to air intercooler on. He converted it to air to air intercooler, but the plumbing was all there already.
The plumming I had to do from scratch as I fitted the front cooler, change the whole inlet system including the air box, snorkel and did the exhaust. So the only thing I could use from the previous conversion was the Turbo charger.....
