Landy bonnet
Has thanked: 193 times
Been thanked: 275 times
Landy bonnet
Ok so I have a bee in "my" bonnet........... :doh:
So here is the question, how strong is the bonnet of the Patrol, and if I put on chequered plate like on a Landy's bonnet will I be able to stand on it???
Ps - would this cause any oil leaks :surprised: QQQ
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Re: Landy bonnet
Post by Russ Kellermann »
My GU 2007 Pickup bonnet is def not strong enough without checker plate, thats for sure.
I dont think any bonnet escaped without subtle damage over time, not even LR's.
Re: Landy bonnet
:rolling: :rolling: :rolling: :rolling: :rolling:
Dirk , you made my day bud !!!.... but on a serious note, the Patrol bonnet is really long, and I found that on mine, even though its a GU and not the GQ like yours, when I fitted the extension to the air scoop to allow more air flow onto the IC, it restricted my view quite a bit, which can be problematic when trying to swing these beasts into the local Checkers parking lots. A 33" tyre is a big tyre and I think if a small platkar stopped infront of you you probably won't even see it until your Patrol spits it out behind you as you drive over it
IanT
Full Name: Ian Temperley
2008 4.8 GRX Umkombe
Re: Landy bonnet
Post by IanT »
Hi Dirk, I have never stood on any of my defenders bonnets, but I have seen people do it and you end up with a dented bonnet unless it has that plate on it (only possible to put that in the middle of the bonnet) There are two structural braces underneath on the bonnet that allows this. Most landy owners do not stand on the bonnet but on the wheel arches, I have seen those wheel arches after the alu plate removed Dented and caved in!!
IanT
Re: Landy bonnet
Post by IanT »
Hay Hay Landies don't leak oil they only mark their territory!!!! :redface:
Re: Landy bonnet
I don't want to stand in the middle of the bonnet -thought, just close to the widow if I want to do something on the roof rack without needing to stretch my small stubby little arms.....
Re: Landy bonnet
Hmmmm.... they sure mark a lot of territory, seeing that they don't travel too far from their garages.....hahaha
Re: Landy bonnet
DIRK .. hello daa -- long time no talk ..
O K .. Ek het 'n ou SAFARI [Patrol] soos Lobo gesien wat die omie angle iron aan die binnekant vasgesit [met nogal blerri mooi boute/moer wat met allan key vasmaak -- bae slim geplaas
Maar dit was n OU Patrol .. of jy so iets op jou Trol wil doen ??????????? hmmmm . besluite besluite..
Ander troos -- as jy net voor naby die ruitveers wil staan .. GEEN PROBLEEm -- ek het die baie gedoen met BOEZMAN en met THOR [my GQ] juis om die daktent op te wen
IanT
Re: Landy bonnet
Post by IanT »
Yes but Cedric, on a quiet night with a Landy you can hear all the other brands rusting!!! :rolling: Did you know that 80% of the Landies ever built are still on the road??? the other 20% have reached their distinations LOL :redface: :rolling:
Re: Landy bonnet
hahahaha.... touché ..... :rolling: :rolling: :rolling: :rolling: :rolling:
Return to “16. DIY Projects”
