Template Board
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Template Board
Post by Bruin Beer »
Guys,
I have seen a soft type thin cardboard used to cut templates before transferring it to steel.
I have been told it is called template board but don't seem to be able to find any info on the net regarding this material.
Are there anyone on the forum that is familiar with material like this or the name of material that is thick enough to use to construct designs from before formal construction?
Thank you for any inputs.
Riaan
Has thanked: 1136 times
Been thanked: 1047 times
Re: Template Board
Riaan, it depends on what you are constructing. I find for bumpers and stuff the best is something quite stiff like normal cardboard, or even hardboard.
Used to have a roll of the stuff you describe (I think) but have no idea where it came from. However, if smallish pieces will do it might be worth asking for off-cuts and scraps at a large photographic printer's shop?
Return to “16. DIY Projects”
