our Patrol (AGAROB) 2002 3,0 Di GRX Automatic suddenly started to go very erratic - one moment all the power is there, the next it just pwfrrrrr ... and all power is gone.. [if I switch to neutral, the engine revs fine but in drive it just crawls ... and when the revs get to 2500+ aftwer a kilometer or more - it suddenly picks up again and goes like it should.
It is life threatening to try and cross an intersection -
I took it to the aapgente - theycome up with a "inhibitor switch" on the gearbox is faulty ... but they cant find that item in the parts lists - now they want to order a "park & neutral control switch" --- takes 21 days from Japan ... none avail in SA...
There MUST be another solution - Guys, PLEASE help ???
Oh - one of its quirks - the car is going like a bat ... then we go through a bump in the road - and pfffffffwwwwrrrrrr... no power, it just idles and takes a loooooong time to get on revs again.
ANYBODY ???????
CRISIS with AGAROB's Gearbox
- Pieter du Toit
- Nickname: PJ of ook Whitey
- Home Town: Welgemoed
- Been thanked: 6 times
Re: CRISIS with AGAROB's Gearbox
Check your inbox for PM!!
Frans ek het hom na jou toe verwys - seker jy sal vir hom lig op die onderwerp kan gee.
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
MUFASA
- Jules
- Full Name: Julius
- Nickname: Jules
- Current 4x4: Pathfinder
- Has thanked: 94 times
- Been thanked: 76 times
I had the same problem on my Merc a few years ago, the one connector to the alternator was shod, replaced it and problem was solved.
Thanx Jules - the old man is with DASTEK now, to receive a plug-n-play chip and hopefully the can trace the problem - I pray that it is just a loose wire or connection or like the connection to tha alt as with your Merc ...
I wil phone Albert and tell him to look at that gremlin as well.
thanx a zillion
groetnis
oompie ..
thanx a zillion
groetnis
oompie ..
- Jules
- Full Name: Julius
- Nickname: Jules
Het netnou met n vriend van my gepraat wat dieselfde probleem gehad het ook alternator koppeling en toe is sy battery in die proses ook erg beskadig. Hoop jy kom reg
Users browsing this forum: No registered users and 14 guests
