Dyno results
- Patrol4.8
- Full Name: Cornelius Kotze
- Nickname: Cor
- Home Town: Wellington (Western Cape)
- Current 4x4: Nissan Patrol 4.8
Dyno results
I took my 4.8 Patrol to Koos Swanepoel developments for a dyno tune and Powerflo for a freeflow system today and here are the results.
1st run before anything was changed: 172.3kw/5163rpm & 377nm/3637rpm
2nd run after freeflow, before chip: 177.8kw/5150rpm & 389nm/3621rpm
3rd run after freeflow, chip and tune: 186.6kw/5254rpm & 416nm/3790rpm
These figures are rearwheel kw and nm converted to flywheel figures.
I will post the graphs later.
Cornelius Kotzé
'03 Patrol GRX 4.8 AT
OME 2" lift
33" BFG A/T
OME 2" lift
33" BFG A/T
- Saltman
- Full Name: Herbie Hellstrom
- Nickname: Saltman
Re: Dyno results
En ... hoe klink hy ??? en hoe trek hy ... en hoe accelerate hy?
Saltman:
- Abri Hoffman
- Full Name: Abri Hoffman
- Nickname: Abri
- Home Town: Monument Park
- Been thanked: 7 times
Re: Dyno results
Lyk goed Cornelius, maar soos Saltman se, hoe klink en voel dit agter die stuur?
Wat was die skade?
Wat was die skade?
2013 FJ Cruiser
"Jack Russel"
"Jack Russel"
- Patrol4.8
- Nickname: Cor
Re: Dyno results
Klink mooi, hy brul lekker as die ruite oop is maar wanneer die ruite toe is kan jy beswaarlik die verskil hoor.
Ek verkies dit so want ek wil nie langpad met 'n geraas binne die kar sit nie.
Dit voel ook of hy sterker trek as vantevore.
Cornelius Kotzé
OME 2" lift
33" BFG A/T
OME 2" lift
33" BFG A/T
- Saltman
- Nickname: Saltman
Re: Dyno results
Cornelius
Watter setup het jy gekies vir die exhaust - sporty klank of die stil ene?
Ek is jaloers - daar is nou eers anner prioriteite voor ek by die ex-chip-chune uitkom!
Geniet hom
Geniet hom
Saltman:
- Full Name: Pierre Becker
- Nickname: Pierre
- Home Town: Milnerton
- Current 4x4: GQ
Re: Dyno results
Nou nog net om die verbruik te sien. Daai figures lyk nice. Wat die grafiek nie wys nie is low load en partial load. Dit is daar waar jy jou brandstof verbruik verbetering sien. Ons sine uit om te hoor wat die verskil is.
- Abri Hoffman
- Nickname: Abri
Re: Dyno results
Baie interresant dat jy teen 2000rpm meer as 400nm het en dit dan afkom en eers by 3500rpm weer daar uitkom. Sal lekker offroad wees maar wat sal die effek op die pad en brandstofverbruik wees.
2013 FJ Cruiser
"Jack Russel"
"Jack Russel"
- Patrol4.8
- Nickname: Cor
Re: Dyno results
Ek het die eerste boks met 'n 57mm pyp vervang, die tweede boks het plek gemaak vir 'n 265/500/2.5 freeflow boks.
Alles agter die tweede boks het ek net so gelos, dit is alles 60mm en freeflow.
Ek het hierdie resep op Roddey by Powerflo se aanbeveling gevolg.
Cornelius Kotzé
OME 2" lift
33" BFG A/T
OME 2" lift
33" BFG A/T
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
Re: Dyno results
Cornelius, daai figures lyk goed!
Dink ek moet n simba chippie laat in sit.
Sucks Gas and Hauls Ass!
