Fellow Oilburners
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Fellow Oilburners
Post by JoshJ »
Hi guys,
Its time for that intercooler fan. I scanned through the intercooler posts and saw there is a "wich way is best" theme going. So wich way is best. The fan ontop or under the cooler. Blowing or sucking? Has anyone done this test? On a intercooler :lol:
And while I'm busy. Whom of you fitted the piet patoors snorkel and if you have do you find that their is an air isseu. That you feel that your air flow to the engine is less.
Any other things worth mentioning about the snorkels will be apreciated. The holiday is almost here and I need to get these 2 items sorted.
Being alive is a Blessing!!
Joshua
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: Fellow Oilburners
Post by David »
Hi Josh
I have one of Piet Petoors snorkels on my 4.8 (I know it is a different model) and I am 100% happy with the quality (.. and I am full of @#$%@...). It had a template and was relatively easy to fit although it took some guts cutting a hole in a perfect panel :lol:
There was no difference in performance and my fuel consumption stayed basically the same so I would say it made no negative difference to the air flow. The main improvement was knowing that I can do water crossings without doubting my wading depth and of course a cleaner air filter on those long dirt roads through Namibia. :thumbup:
Been thanked: 473 times
Josh, those fans will work either way. They are high volume low pressure fans, so it doesn't matter if its fitted on top or under the intercooler. If the air is restricted the flow doesn't happen. Mine is fitted under the IC, but it depends on the space you have available between the bonnet and the IC or IC and motor.
nick vc
Full Name: Nichalas van coppenhagen
Nickname: nick vc
Home Town: Port Beaufort
Current 4x4: 2001 patrol 3.0 td grx
Home Language: english
Post by nick vc »
Hi There . Is an intercooler fan standard ? I mean would my 2001 grx 3.0 have come out with one and if so where would it be situated ? If not why should I have one installed ??? :doh: :doh: :doh:
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Post by Stefan »
The turbo diesels don't come standard with a fan on the intercooler.
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Through my years of experience just the following , blowing cools down and sucking heats up
Ummmmmm.... Jules... ummmmm... I don't quite know how to read that statement..... :rolling: :rolling: :rolling:
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Easy Ricster read it from the point of view of a Petrol head :woo:
shalom
:rolling: :rolling: :rolling: ..... right...... got it....hahaha
Stefan
Nickname: Stefan
Post by Stefan »
Whoa down boy!
:rolling:
