IanT
Posts: 1234 Joined: 17 May 2013 10:43
Full Name: Ian Temperley
Current 4x4: 1995 GQ 4.2 Petrol (Turbo Charged) (Hell Boy) 2008 4.8 GRX Umkombe
Been thanked: 92 times
Post
by IanT » 07 Aug 2014 16:20
Quick question guys what fuel are you putting in, to your petrol Patrols (lets keep the oil burners out of this they run on an oily rag anyway
) Up here on the reef I have always put in 93 (it uses so much I try to save penny's where I can) Would there be any advantage running it on 95???
Posts: 7590 Joined: 29 Aug 2010 13:07
Current 4x4: Nissan patrol 4.8 GRX 2005 Toyota 2.7 legend 35 LWB 4X4
Has thanked: 802 times
Been thanked: 562 times
Post
by Tinus lotz » 08 Aug 2014 06:50
Ian afaik the compression rasios in the petrol engines are to low to use the higher octane feul correctly. But let Piet or one of the clever guys explain
Posts: 5853 Joined: 13 Jan 2010 11:16
Has thanked: 591 times
Been thanked: 473 times
Post
by ricster » 08 Aug 2014 08:17
"sits quietly in a corner and listens "
Posts: 2999 Joined: 08 Apr 2009 07:17
Current 4x4: 1999 Patrol 4500e GRX 1983 Datsun Safari
Has thanked: 55 times
Been thanked: 94 times
Post
by Herrie » 08 Aug 2014 09:27
I only use 93 because it is cheeper!
Posts: 6138 Joined: 10 Sep 2010 07:21
Has thanked: 1124 times
Been thanked: 1038 times
Post
by Peter Connan » 08 Aug 2014 13:20
95 can't do any harm, but on the other hand you probably won't derive any benefit from it either.
However, if you are filling up here for a trip to the lowveld or coastal regions, chuck in 95...
dieselfan
Posts: 314 Joined: 27 Feb 2010 23:39
Full Name: Roy Markham
Nickname: Roy
Has thanked: 2 times
Been thanked: 2 times
Post
by dieselfan » 08 Aug 2014 15:02
Ever since I won the lotto I only use 95 in Jhb...otherwise as per Peter.
BABELAAS
Posts: 116 Joined: 03 Jan 2011 13:30
Full Name: LOWE
Nickname: MARC
Home Town: BRONKHORSTSPRUIT
Current 4x4: 2015 Navara 4X4
Home Language: ENGLISH
Been thanked: 3 times
Post
by BABELAAS » 10 Aug 2014 03:40
personally, I haven't found any difference in 93 or 95, so I use 93
BABELAAS
2015 Navara 4X4
Posts: 2859 Joined: 25 Jul 2012 08:36
Has thanked: 189 times
Been thanked: 270 times
Post
by offroadbiker » 12 Aug 2014 08:06
On our trip to Giyani this past weekend there was no 93 past Polokwane only 95 was available, wasn't sure if the GQ could take 95
NISMOnator
Posts: 327 Joined: 01 Apr 2012 14:44
Full Name: Jacques Strauss
Nickname: NISMOnator
Has thanked: 19 times
Post
by NISMOnator » 12 Aug 2014 13:50
We have only been putting in 95! If there is really no difference and it cannot harm the engine - 93 that is.
Then I should start converting to 93?
Is the 4.8 all good with 93?
Interesting thread this.
Stefan
Posts: 1692 Joined: 28 Apr 2009 08:43
Full Name: Stefan de Villiers
Nickname: Stefan
Has thanked: 175 times
Been thanked: 50 times
Post
by Stefan » 12 Aug 2014 14:20
500ppm
50ppm if I'm feeling extravagant!
