Electric arial
Tunja
Full Name: Ernest Tunnah
Nickname: Tunja
Home Town: Swakopmund
Has thanked: 9 times
Been thanked: 18 times
Electric arial
Post by Tunja »
HI Guy's my one has arrr sommer "parted" in the middle during a trip :rolleyes: so looking for either a Nissan one or what else can I use?
Re: Electric ariel
I have replaced 2 electric ones and broke them off on trees ect
Just put a wip tipe that can bend :mytwocents:
Has thanked: 61 times
Been thanked: 258 times
Re: Electric ariel
Ek stem
The telescope is a patent waiting to get wipped by trees.
Got a wip instead since. Cheaper last longer, and easily replacable from Midas
Re: Electric ariel
Yaaaaaaahhhhhhhhhhhhhhh -- put a whippy arial there -- reception also much better coz you can CUT IT RIGHT LENGTH :-) :biggrin:
Then - do NOT throw away the motor that drives the arial ..use it to drive a rotaserie for when you chicken braai in the bundu ... :woo: :woo:
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 29 times
Been thanked: 136 times
Re: Electric ariel
Post by ChristoSlang »
I also stem saam...
Bought a short bee-sting antenna for Chuck that works perfectly. The antenna can be unscrewed from the base if you really want to rough it with those roller-type car washes. They're so cheap (around R50) that I bought a few of them - just in case I forget to screw it back on after visiting one of them scary car washes.
Christo (the snake man)
Tunja
Nickname: Tunja
Re: Electric ariel
Post by Tunja »
Kagiso II wrote:Yaaaaaaahhhhhhhhhhhhhhh -- put a whippy arial there -- reception also much better coz you can CUT IT RIGHT LENGTH :-) :biggrin:
Just got to love this forum.... :biggrin: :biggrin: :biggrin:
Re: Electric ariel
Hmmm .. Tunja you agree -- or you think is not possible?? :think: :think: :think: :rolleyes: :confused:
Re: Electric ariel
The whip aerial was one of my first mods :thumbup:
rvanrooyen
Full Name: Roland van Rooyen
Nickname: Roland
Home Town: Cape Town, Mamre
Current 4x4: 2000 Nissan Patrol 4.5 GRX
Been thanked: 4 times
Re: Electric ariel
Post by rvanrooyen »
How difficult is it to replace the antenna? Do you have to remove the fender? Where / how do you plug it into the radio?
Re: Electric ariel
Its relatively easy. You need to remove the screws that hold the plastic wheel well cover in place, and the screws for the mud flap, then unbolt the (I think) 10mm bolt that holds the electronic box in place then loosen the nut ( outside on the fender ) holding the aerial to the fender, then unclip the wiring plug, and Bob's your aunty. REMEMBER to tape a piece of wire to the aerial cable going into the cab so when you pull the old cable out you tape on the new aerial cable and just gently pull it back into the cab to connect back into the radio.
