Air conditioning service - with or without lubricant?
Florian320
Full Name: Florian M.
Nickname: Flo
Home Town: Hoedspruit
Current 4x4: '99 GRX 4500
Home Language: German
Has thanked: 42 times
Been thanked: 34 times
Post by Florian320 »
I am not sure wether engine or electronics is the right chapter, so I'll post it here:
I am thinking of doing an air conditioning service. As I am staying in Hoedspruit, the facilities are not so high-tech.
That means, the local a/c-company only checks and changes / fills the refrigerant, not the lubricant.
Does anybody have a clue how to check wether there is enough lubricant in the system? Did you ever refill the lubricant or did you also only refill refrigerant? Is i both filled through the same connectors?
Thanks for your advice!
Re: Air conditioning service - with or without lubricant?
I have never heard that you must use anything extra for the aircon service.
Are your aircon not cooling properly or do you want to just do preventative maintenance?
Just check the one before the radiator for grass and seeds that can make the system suffer
Florian320
Nickname: Flo
No, it would just be preventative maintenance.
It even sees xxx kg refrigerant and yyy (I think 300) ml lubricant on the sticker in the engine bay.
But maybe that is something you don't need to do often - to change the lubricant?
firessafari
Full Name: Johan van Vuuren
Nickname: Johan
Current 4x4: Safari s/w
Been thanked: 7 times
Post by firessafari »
Your air-conditioning system is a closed system thus the oil does not escape from it; not like the gas that escapes through the rubber hoses, so you never need to add oil except if you got a broken hose, condenser or evaporator. I believe your system is charged with R134a gas so the oil is polyalkylene glycol (PAG)
or polyester at R244.00 a litre and you must flush the system with a special R141b flushing agent at R508.00 per litre then you need to replace the receiver drier. The oil and refrigerant mix in the system and runs through the whole air-conditioning system so it not a matter of topping up , it must be filled as per manufactures specifications before recharged with refrigerant so don't fix it if not broken, the oil is supposed to last the life of the vehicle same as with your fridge at home.
Johan
Florian320
Nickname: Flo
Hi Johan,
that is what I thought respectively hoped of, but I wasn't sure.
Thank you very much for your post, so I can only refill the refrigerant without bad feelings.
Best regards,
Florian
Been thanked: 430 times
Hi Johan
Interesting post you made and very helpful.
Where can I purchase the refrigerant oil? I am in Pretoria area
firessafari
Nickname: Johan
Hi Michael.
You can get the oil from Macs spares in Krugersdorp http://www.macspares.co.za/refrigeratio ... 20a&page=2
You can also get these oils and consumables at Tecsa Raco , I am sure they may have a branch in Pretoria But make sure you get the right oil for your application these oils are not interchangeable ,The Poly oils are synthetic and the oils for home air conditioning that uses R22 gas as well as older automotive air conditioners and fridges using R12 gas uses mineral based oils . remember these synthetic oils do not store well so once open use it since it draws water .
firessafari
Nickname: Johan
Florian The only maintenance that you can do on your air conditioner is to periodically say every 14 days is to switch the unit on and run it for about 10 minutes while driving, the reason for that is I mentioned in previous posting is that the gas and oil is a mixture in your system and by circulating that the oil covers the inside of the hoses thus preventing the gas from escaping through the rubber (The same as a tyre getting flat over time).
Johan
Florian320
Nickname: Flo
Thanks Johan!
