4.8 Coolant Replacement
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Post by Bruin Beer »
Guys,
Stumbled across this very useful information (certainly to me).
A while ago I drained the coolant on my4.8 to remove the thermostat housing as it started to show a slow leak where the housing started to corrode. As the coolant was fairly new because I replaced it not to long ago I drained it into a container.
Did the hole job and replaced the original coolant back into the system.
I knew I had an air lock as I was not able to get the amount I drained back in.
I started the engine to circulate the coolant and push the air out.
I continuously felt the hoses to determine when the thermostat open at which point I intended switching off and add water.
After a few minutes, and with the hoses still cold I suddenly realise something is wrong as the electric cooling fan came on. I immediately shut down the engine and could feel the block was warm but still no water flowing.
The heat of the block eventually conducted to the thermostat housing and eventually heated the thermostat to open enough to get the trapped air through.
Yes, while it was out I did check the small check valve and that was operating and perfect.
Well I stumbled across the following coolant bleed valve which I am convinced would have prevented the close call with great expenses.
Drawing1s.pdf
Wide angle
(495.25 KiB) Downloaded 1452 times
Drawing2s.pdf
closeup
(357.67 KiB) Downloaded 1133 times
Remove the plastic engine cover ( four 10mm screws) to expose the engine.
The read circle and yellow arrow indicate the bleed valve which according to the manual should be removed for draining the fluid and keep it open when refilling and only close when the water start to come out the bleed valve.
I will definitely follow this closely next time.
I am sure this would make the worlds difference and hope this could save someone else's bacon.
Bruin Beer
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Re: 4.8 Coolant Replacement
Post by Chris Skinner »
Really close call!
Thanks for the heads up... :thumbup:
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Post by Clem »
That advice is worth money! Thank you!
:thumbup:
BABELAAS
Full Name: LOWE
Nickname: MARC
Home Town: BRONKHORSTSPRUIT
Current 4x4: 2015 Navara 4X4
Home Language: ENGLISH
Post by BABELAAS »
Great tip , Cheers
BABELAAS
2015 Navara 4X4
Vloot
Full Name: Johannes Rath Groenewald
Nickname: Vloot
Current 4x4: Patrol Pickup TD42 2007
Post by Vloot »
:goodpost:
