Front bumper removal
Andrewfus
Full Name: Grant Andrew van Staden
Nickname: Andrewfus
Home Town: Rustenburg
Current 4x4: NavaraD40
NavaraD22
Post by Andrewfus »
Any tips or techniques???
Anything that I should watch out for?
Its a 4.8 2013.... I see a gazillion bolts that are holding the bumper...
Andrew van Staden
Navara 4x4 - D40 and D22
Ex: Nissan Patrol 4.8 GRX
Ex: Ford Everest (Unmodifiable)
Ex: Suzuki Jimny (With some tricks)
Ex: Defender 110 Puma - Martha http://www.4x4community.co.za/forum/...d.php?t=135038
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Front bumper removal
Post by AndriesS »
most bolts keep the plastic to inner strengthener of the bumper.
undo the plastic triangular covers just in front of the front wheels that screws to the side of the bumper to the inner fender. you should be able to disconnect the fog lights now. I can't recall if I undid the bumper from the top (i.e. removed the grill or from the bottom. Undo th4 bolts ( I think 2 each side that holds the strengthener on the chassis rails. I think that was it, don;t need to undo al those 10mm bolts .
Andrewfus
Nickname: Andrewfus
NavaraD22
Post by Andrewfus »
Thanks.
So you say I can remove the whole bumper by loosening the 4 main bolts.... :blonde:
I will look again this afternoon. :woo:
Andrew van Staden
