Suspension bump stops
Unkredible
Full Name: Bruce Williamson
Nickname: Unkredible
Home Town: Rivonia
Home Language: E
Has thanked: 27 times
Been thanked: 24 times
Post by Unkredible »
Has anyone replaced their suspension bump stops? I have noticed that mine are all badly cracked / missing...
285x75x16 MT
DC-DC Charger
Re: Suspension bump stops
Hmmm only seeing this now.... did you manage to come right with these.... my front ones are looking sad too
Has thanked: 62 times
Been thanked: 257 times
Cedric, besides looking bad, what have been the symptoms if any?
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Current 4x4: 2005 4.8 GRX
Been thanked: 102 times
Post by bogeyman »
When replacing the coil springs on my GQ we broke the rubber balloon end on both sides.
They were not in good shape and basically fell off when the old coils were removed.
Still waiting for replacements and driving without them.
I find the suspension bottoms out easily with a nasty bump and those things are definitely part of the total suspension setup.
Those little round ends act like an air cushion.
I did get a little better flex without them!
marakasmalan
Full Name: Marnus Malan
Nickname: marakasmalan
Current 4x4: '94 Patrol SGL
Been thanked: 16 times
Post by marakasmalan »
R387 from Nissan (incuding a 10% disc.)
Trouble is getting the old ones off - the bolt seperates from the rubber and just turns around inside the bump stop.
Has thanked: 1141 times
Been thanked: 1049 times
Then it becomes a big job, unless there is enough room to drill out the bolt head from the top?
If not, one would probably have to remove the front springs, then tear out the rubber and cut the bolt off?
marakasmalan
I used a "renovator" and cut the bump stop off, exposing the bolt to be clamped with a vice grip.
https://www.verimark.co.za/products/renovator
Alex, I haven't noticed any difference but am worried the suspension will bottom out as my rubbers have also lost their balls....wait that sounds soooooo wrong......
R387 from Nissan?? was that for one or for both??
marakasmalan
vir 1 f#$%&$%^% stukkie rubber. Dus, 'n stel = R 387 x 2 = R774.
Ek het die slag net 10% afslag gekry - partykeer gee hulle 5, ander kere 20 maar die keernet 10.
Unkredible
Home Town: Rivonia
Home Language: E
At that price, I will live with the broken ones...
:doh:
285x75x16 MT
DC-DC Charger
