Front Axle Lockers
Johan Fourie
Full Name: Johan Fourie
Nickname: Johan
Home Town: Cape Town
Current 4x4: 2000 Nissan Patrol 4.2 GL Diesel
Has thanked: 1 time
Front Axle Lockers
Post by Johan Fourie »
I would like to install front axle lockers on my 4.2 Patrol. Except for ARB, what other brands are available on market that does not cost the same price as the vehicle? Please assist me with info. Thank you
Has thanked: 62 times
Been thanked: 257 times
Re: Front Axle Lockers
Hi Johan
There are alternatives, but I am not so sure about after market services, and their SA support.
One that had been referred to earlier on this forum is "Eaton E-Locker"
Apparently at least as good as ARB, with fewer moving parts and no risk of air leakage since it is magnetic.
I have no idea where to source these in SA though.
http://www.patrol4x4.co.za/viewtopic.ph ... ers#p33672
What I would do if front lockers was a priority right now, is to find out what the lockers of choice are on the Ozzie Patrol forum. http://nissanpatrol.com.au
There are plenty of Troll drivers there so their opinions on alternatives to ARB would be valuable.
Then find out about their installation and servicing capabilities in SA.
Other sources that you may want to consider:
http://www.4x4traction.co.za/info.php?prod=1521
http://www.4wdsystems.com.au/index.php?id=29
http://www.richmondgear.com
Has thanked: 1142 times
Been thanked: 1049 times
The cheapest option is an auto-locker. 4x4 Traction (one of the links Alex posted above) supply and fit the Lockright unit.
They are strong, but also have an impact on vehicle dynamics that some find unacceptable.
Johan Fourie
Nickname: Johan
Has thanked: 1 time
Thank you Peter & Alex for your quick response. I will have a look at the options :thumbup:
Johan Fourie
Nickname: Johan
Has thanked: 1 time
I have finally fitted a ARB Front locker on my Patrol. It works like a dream on rock obstacles...you sail over the rocks as if they are not there.
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Hi Johan,
If i may ask, who did you go through and were you satisfied with the workmanship. I am very pedantic about workmanship, and my biggest fear is during reassembly as i simply dont trust anyone these days to reset matters to the exact specs as per factory..
Thoughts?
Johan Fourie
Nickname: Johan
Has thanked: 1 time
Russ...I went to 4x4 Megaworld in Paarden Eiland. Their work is of very high quality and the technician fitting locker knows his work. Don't use Summerset West branch...they farm the work out to some private company becuase they have now one that can fit lockers.
For R5000 i fitted full time lockers in th car and it goes anywhere.. it is called AUSIE LOSCKERS, they work a charm and cost less.
Miken imports thm for your veehaicul spcific and goes with when it is installed.
contach MIKE SWANN on +2u7825694183
tell him you are wit PATRO forum and oompie sent you.... you want a decent price
I an saving up to put a set in Dwergie;s JIMNY kum krismistaaim
Oom Mac
Watter kar was dit voor?
En hoe het jy jou draaisirkel ervaar na die tyd? Was dit die selfde?
Johan Fourie
Nickname: Johan
Has thanked: 1 time
I got quotes from each and every supplier and also directly from suppliers overseas and they where all more expensive than the ARB Locker. That's why I went for it. The other more important thing to remember is your "Guarantee" ARB has got local S.A guarantee...and the rest of the lot...your own problem and your own loss.
