PATROL ENGINE GEWIG
Vellies
Junior Member
Junior Member
Full Name: Pieter Putter
Nickname: Vellies
Current 4x4: whannabee Patrol owner
Home Language: Afirkaans
PATROL ENGINE GEWIG
Post by Vellies »
Help asseblief.
Ek sal waardeer as iemand dalk vir my kan se wat weeg die 4.8 petrol en 3.0 diesel Patrol engines onderskeidelik.
Dankie
Re: PATROL ENGINE GEWIG
I presume that the 4.8 petrol motors head is aluminium, that being assumed I would say that even though the ZD30 diesel motor is only 4 cylinders, the weight would be pretty close to the 4.8 Petrol, as the head will be cast iron. You don't want to know the weight of the old TD42 diesel motor..... :surprised: .... 6 cylinders and a cast iron head .....hahaha
Ek het al n 4.2 probeer rond beweeg .....hulle is baie swaar miskien moet jy jap auto bel en by hulle uitvind of google vra ?
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
When you find out , please let us know.
Vellies
Junior Member
Junior Member
Nickname: Vellies
Post by Vellies »
Chris Skinner wrote:When you find out , please let us know.
Maak so.
Die rede hoekom ek vra - ek wou net kyk of die engines in die link te swaar sou wees vir die Patrol -
http://www.vmmotori.com/automotive/automotive-en.html
Ek het gedink daai A630 of A428 sou n flink ombouing wees as mens dit as n "crated engine" met control computer kon koop vir `n hand ratkas.
Ek het nou al gevorder tot die punt waar ek `n telefoon nommer in Europa het om te bel om uit te vind oor die engins.
Has thanked: 1134 times
Been thanked: 1044 times
Very impressive maximum outputs!
I am pretty sure the 630 is lighter than the 4.2 Petrol, or at least in the same ball-park, but:
What quality of diesel do these engines need? Also, if the exhaust manifolds don't fit, you are going to have a serious problem.
I also feel that the bottom en is a bit lacking for a Patrol, as the Patrol has a relatively high low ratio (although aftermarket ratios are available to rectify the problem, but it all adds cost).
Bekker
Full Name: Bekker van Niekerk
Nickname: Bekker
Home Town: Wellington Westren Cape
Current 4x4: None
Post by Bekker »
Peter Connan wrote:Very impressive maximum outputs!
Hi Vellies
Ek dink ( vermoed ) die A428 is dieselfde engine as in die 2014 JKU Jeep 2.8 CRD en ek dink ek het iewers gelees daar is agente op George wat daardie engines kan voorsien. Stanmar Motors George behoort jou meer informasie te kan voorsien. 044 802 7049
Bekker van Niekerk
0828017117
bekker@paarlrek.co.za
I weighed my TB42
Complete with clutch and manifiolds (inlet and exhaust) but without any ancilliaries (air-con, power steering, alternator osr starter), it's about 250kg.
Vellies
Junior Member
Junior Member
Nickname: Vellies
Post by Vellies »
Dankie Bekker.
Dis moontlik hulle doen ook diens in RAM trokkies. Ek dink tog so motortjie sal `n Patrol lekker stoot as mens nou al die klein goedjies wat ek nie ken nie kon uitsorteer. Hoe dit ook al sy. Dit bly lekker om te droom.
Chris Skinner
Nickname: Chris
I also have a Jeep Cherokee 2,8CRD - that little diesel engine really pumps and very efficient - I get ave 9ltr/100km.
Will do well in a Patrol body! I also had a Jeep 3L V6 Diesel - Of course with 510nm it is awesome.
Jeep 2,8 CRD = 119KW, 400nm - body weight is 1950kg
Patrol 3,0 = 110KW, 371nm - body weight is 2355kg
