The monitor inside the car
The monitor up close
The VDO Boost Sensor installation (bought from control instruments in Epping)
The VDO Sensor up close
Currently I monitor the follow functionality from one monitor:
Battery voltage meter with a high and low alarm setting
Vehicle running hours
EGT Degrees with a high alarm @ 750 degrees
Boost with a high alarm @ 1.2 bar
Pitch and Roll
Artificial Horizon
The monitor allows you to either page through each screen yourself or automatically display each screen with a time setting from 1 sec up to 60 sec per screen. Other functionality on the monitor still available:
Oil Pressure
Coolant level allowing for off road purposes
Auxillary realay for switching on a fan or something similar.
I will post photos later of each screen display - but it is a nice all in one monitor if you going to use the functionality of it.
