GQ Body Mount Bolts
Zantus
Full Name: Barto de Koning
Nickname: Zantus
Home Town: Port Elizabeth
Been thanked: 5 times
GQ Body Mount Bolts
Post by Zantus »
So, I have this very irritating clucking noise coming from under the driver and passenger feet on my GQ. I search around on Patrol forums and eventually found that it is the bodymounts.
So, on Saturday, I thought I'd loosen the nust and see what's up, BUT.....the bolts turn with the nuts :surprised:
How do I get to the head of the bolts, I cannot see any way to get to it from below. Can you get to it from inside the car by lifting the carpets?
I don't want to rip out the interior and find that I've gone down the wrong path.
Re: GQ Body Mount Bolts
Mark greenhill did his ones about 3 months ago will get him to answer you :thumbup:
Zantus, take off the strips under the front doors (some phillips screws), then lift the carpet slightly, and you will see a rubber grommet. Lift that out, and the bolt head will be visible.
slmr
Full Name: Shane Swart
Nickname: slmr
Current 4x4: '95 Patrol 4.2 SGL
Has thanked: 1 time
Post by slmr »
Zantus,
If you lift the carpet and find that it is a square piece of plastic and not a grommet, then you are in for a four-handed mission to remove the captive nut-holder-plastic-@#$^&-thing
Cannot remember if the front inside-cab ones had those plastic thingys
I destroyed 2 before I got it right to remove them- 0 eight 2 3 seven 2 9 2 eight 6
Mark Greenhill
Full Name: Mark Greenhill
Nickname: Mark
Home Town: Greenstone
Current 4x4: 2004 Nissan Patrol GU Y61
Location: Greenstone (Edenvale / Modderfontein) Johannesburg
Has thanked: 1 time
Post by Mark Greenhill »
Hi There
I have a 2001 4.5 GRX, All I had to do was unscrewt the body mounts from under the car. Never had to remove any carpects.
Mark Greenhill
2001 Nissan Patrol 4500 GRX
