Auto locking hubs.......HELP Please!!!!!
- Ink
- Full Name: Jaques Horn
- Nickname: Ink
- Home Town: Middelburg Mpumelanga
- Current 4x4: 2000 4.5 patrol gl
I Have a problem and not sure what it is.
If I drive some times I hear a GRRRRRRRRRR sound at my front right wheel, when I stop to check .... the moment when the patrol gets to a full stop it goes gwa and I can feel the shot straight to the rear diff. Cant see any problem when I then drive again all OK. Does any body know what this might be. I think it might be the hubs locking or????????
Life is a journy, enjoy the ride
Re: Auto locking hubs.......HELP Please!!!!!
It the setting of the wheel hub properly in the "Free" area?
- bogeyman
- Full Name: Christo Boegman
- Nickname: Chris
- Current 4x4: 2005 4.8 GRX
- Been thanked: 102 times
The sound you hear is the free wheel hub trying to engage. This happens when the grease becomes sticky due to age or when cold.
The sticky grease then mimics the auto lock action inside the hub. The hub teeth are moving at different speeds and grind together until violently engaging when you go slow enough. It is not good for drivetrain components.
Remove the hub lock assembly , clean and regrease with the Nissan prescribed grease. I know the correct grease to use has been discussed on another thread.
To remove the freewheel lock , first set the selector to "lock". Then remove the six allen key retaining bolts.
The locker will now come free from the hub. Slight hammer tap might be needed. Don't try and disassemble that locker. You will never get it together and working again. Just wash it with degreaser , apply new grease and re assemble in reverse order.
Hope this helps,
Chris.
Hope this helps,
Chris.
- Ink
- Nickname: Ink
Thanks Chris
Will do this the week end
- Has thanked: 1141 times
- Been thanked: 1049 times
If you need to drive it before you can get around to fixing it, manually lock the hubs (both hey). This will only have a slight increase in fuel consumption, no other negative side effects.
- Full Name: Clem Daniel
- Nickname: Clem
- Current 4x4: Patrol 4.8
- Has thanked: 39 times
- Been thanked: 39 times
Peter, IIIRC that's what the manual says as well for the cold grease situation.
FWIW, I see some folk remove the auto-locking component altogether from the unit. This then enables the use of 2wd low range on hard surfaces - for example maneuvering a heavy boat on a slipway. There are online articles on how to remove it. Seems quite straightforward.
- Full Name: Roy Markham
- Nickname: Roy
- Been thanked: 2 times
I want to remove mine. My dads patrol is manual and I prefer that. I want a Nissan 76.
- Ink
- Nickname: Ink
Took both mine apart today one have broken part inside, other still good cleaned greased and assembled. It's easy to make it manual like the assists does. O Ja and easy to strip and assemble again too. But to the short my one hub is shot (after it did 458000km) now where to find new one or sommer get 2 manual ones.
