handbrake light stays on
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
My GQ went to Ferrobrake so that they could clean the left rear brake calipher since it was getting very hot on rim and nuts, everything is still in good nick,but I am going to get new seals from the chaps in Alberton, my queztion now WHY DO THE HANDBRAKE LIGHT STAYS ON.When I collected my lorrie the light was not on but going home it stayedon fod the full 21 km
Re: handbrake light stays on
Jukes
Kyk of daar nie 'n micro switch is wat êrens pla nie.
Has thanked: 1136 times
Been thanked: 1047 times
As ek reg onthou sit die skakelaar binne-in die kar by die rathefboom. Ek glo dus nie die probleem het enigiets te doen met die werk wat gedoen is nie.
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
More, dink ek het die culprit uitgesorteer, het gisteraand laat vinnig gekyk hoe vol is die brakefluid bottel, hy was redelik onder minimum ( hul het obviously die remme gebloei tydens die inspeksie ) Het bottel tot net onder maks volgemaak en vanoggend was ligggie af. Ek sal nou maar net monitor maar gaan in elke geval nuwe seels van die ouens kry
BERAS MOTORS SPARES
Phone: 011 901 3100
Physical Address:
48 Pieter Uys Ave, Alberton, 1449
Postal Address:
PO Box 6064, Alberton North, Alberton, 1456
If single piston, part no should be P1388S Partquip (48mm)
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Ek wonder nou net of mens nie hierdie Partquip sommer by Midas, Spares Shop of ander spares plekke ook kan kry nie ??
Hey Jules.... what you doing in my neck of the woods.... LA, no not Los Angeles, Lower Alberton is making it on the Durban map..... :rolling: :rolling: :rolling:
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Hi Cedric, I have some Mafiosa connections there QQQ , will inform you when I am again in that area
:thumbup: :thumbup: .... cool, we can grab a cold one and enjoy a chat!!
