GQ Rear Brakes
Stefaansie
Full Name: Andre Vorster
Nickname: André
Home Town: Benoni
Been thanked: 9 times
GQ Rear Brakes
Post by Stefaansie »
Hi Guys,
Hope someone can help,
Is it a big thing to convert the rear brakes from drums to discs? I would really like to have some better stopping power. I don't understand that my truck is the only one that came out with drums in stead of discs. Unless its not the original axle.
Would be interesting to know.
'96 SGL-D PATROL (GQ)
ECHO 3
'07 SUZUKI BOULEVARD 1800
'06 YAMAHA 700 RAPTOR
Has thanked: 1136 times
Been thanked: 1047 times
Re: GQ Rear Brakes
Andre, drums work fairly well untill they get either hot or wet.
If it is just stopping power you want, I suspect your money might get better results if spent at the front end?
Re: GQ Rear Brakes
Jy kan oorboord gaan en dat OX van "Old School" conversions vir jou n Jaguar XJ6 se discs voor en agter opsit ..
(Daai Jag discs is n fraksie van Patrol se discs)
Ek vermoed jy het ou Safari agteras op .. die GQ het met agter discs gekom so ver ek weet .
Watter jaar is joune?
Re: GQ Rear Brakes
Oom Mac, meeste van die GQ diesels het dromme agter...
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Re: GQ Rear Brakes
Post by Grant »
Hi Peter,
Not sure about that. I know that the GQ patrols have the safari brake system, but mine has discs.
GQ Owners
Rear brakes Discs
1. Grant
2.
3.
4.
5.
Rear Brakes Drums
1. Steffansie
2.
3.
4.
5.
Stefaansie
Nickname: André
Home Town: Benoni
Re: GQ Rear Brakes
Howdy,
My GQ is a '96 model.
Methinks the LS diff is on the way out as well. It vibrates when driving at a constant speed on the highway.
So, my next question:
Can one change the ratio on the newer 4,5 or 4,8 diff( with a nice diff-lock) from a 3.999:1( i think) to a 4,111:1?
Will it be cost effective? Or do you think I should stick with the drums and fix up the LSD?
I'm just trying to weigh all my options here.
Your advice would be appreciated.
ECHO 3
Re: GQ Rear Brakes
Mabe speak to dawid volskenk and get a spare diff with disks and working diff?
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Re: GQ Rear Brakes
Post by Grant »
Andre,
Just have the LS repaired.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: GQ Rear Brakes
Post by David »
Or just make sure it has the right oil - the limited slip diff requires a different oil than normal diffs. Castrol LSX is a good choice!
Stefaansie
Nickname: André
Home Town: Benoni
Re: GQ Rear Brakes
Thanks,
Ek waardeer die input.
ECHO 3
