Good morning all. I am hoping someone can help me find the engine number on my 2001 3.0 Diesel Patrol. There is a number stamped on the cylinder head, RH side looking at the engine from the front, but where is the number stamped on the block?
Many thanks
2001 3.0 D engine number
- Has thanked: 1124 times
- Been thanked: 1038 times
Re: 2001 3.0 D engine number
According to the manual, that's where the engine number is.
The ZD 30 engine's number is stamped on the cyl head ONLY [and on the VIN plate] but the engine only position is the cyl head [AS jy die cyl head vervang, moet jy die ou nommer daarop oordra ..
Enigste voertuig wat ek van weet .. as jy die Cyl head vervang moet jy die voertuig se registrasie dok ook laat veranter by die registrasie owerhede .. [murse frustrasie] Toe ek Boezman nuwe head opsit wou die moer dat ek hom deur die toets weer sit ..
Gmffff - that never happened ..
Guppy -- to answer you - the ZD 30 engine [PATROL; TERRANO and HARD BODy ] .. enigine no only appears on the cyl head
Yes IanIanT wrote:Hay Peter, is you lorrie up and running now?
Check my trip report?
