Power Steering Fluid
Tony
Full Name: Antonio Barone
Nickname: Tony
Home Town: Greyton - W/Cape
Been thanked: 40 times
Post by Tony »
Hey guys, was checking all fluid levels on Sunday evening, and noticed that my Power Steering Fluid reservoir showed no oil on the dipstick when cold. Popped over to Midas today to pick up a bottle, but the guys wanted to know which one I wanted??? They seem to go by colour so I left it and rather decided to check with "the boffins" what the correct fluid is, and if places like Midas sell the right quality stuff? Anyone know what to use - (3.0 TDI Manual).
Thanks.
Re: Power Steering Fluid
Tony - I had Agarob's steering fluid drained and put in new -- but you use nortmal ATF [automatic transmission fluid] The Castrol I put in was reddish.
On the lid should be the specs of which ATF is advised by the manufacturer -- get the ATF nearest that spec?
Tony
Nickname: Tony
Post by Tony »
Thanks Oom, I also seem to remember mine being a reddish colour.
Has thanked: 1134 times
Been thanked: 1044 times
I can't remember 100%, and the info is at home now, but it is not the normal ATF, it is a higher-spec ATF. I think it is GL2, but am not sure...
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Post by Bruin Beer »
Guys,
The manual suggest DEXTRON III ATF.
I bought Castrol from Midas.
Hope this helps.
Bruin Beer
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
Dexron III is correct : see Recommended fluids :thumbup:
Tony
Nickname: Tony
Post by Tony »
I found it in the manual this morning - listed as DEXTRON III ATF. Bought something called Transmax Dex III ATF at midas today and the colour is the same. Does this sound like the right one?
timfairmoz
Full Name: Timothy Fair
Nickname: Tim
Home Town: Mozambique
Current 4x4: Nissan Patrol 3.0Di
Post by timfairmoz »
Hi guys,
Need to top up my PSF (Patrol 3.0Di). Manual recommends NISSAN PSF or Dexron VI - Anybody know where I can get Dexron VI? Seem to only find II and III available.
Thanks in advance.
