GQ without clutch
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Monument Park
Current 4x4: 2013 FJ Cruiser
Been thanked: 7 times
GQ without clutch
Post by Abri Hoffman »
Tuesday morning Debbie arrived home from dropping the kids at school and phone me to say the Patrol's clutch is gone and she can get it in gear.
Got up from bed with the flu, put the car in LR, start without clutch and pulled into the yard.
Check the mastercylinder fluid level - no breakfluid
Look under the car and see brakefluid over the exhaust.
I had 'n new system installed two weeks ago and they did not install a heatshield above the new exhuast.
Seems the slavecylinder overheated and started P1ssing out breakfluid.
So i start removing the slavecylinder and hoses. Clean everything and cannot see any damage.
I replaced everything and started bleeding the clutch to see if I can find the leak.
Luckily it seems to be the hose connecting the master and slave cylinders.
Off to Nissan to enquire about the hose. None in stock but they will order from Japan. Will take approximately 3 weeks.
Paid my R284 for the hose and checking the breakfluid (clutch fluid) level daily.
Since I have to wait for the hose and still have to use the car I though of buying some wondertape and rap it around the hose as it is leaking where the metal is crimped over the rubber and see how good the product is.
In the mean time I also will have to get a heat shield to prevent future damage.
So lets see how good this wonder tape really is. :think:
2013 FJ Cruiser
"Jack Russel"
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Re: GQ without clutch
Post by Jules »
Abri kan mens nie n stukkie pyp by een van hierdie honderde hydraulic ouens koop wat sal werk nie?
Abri Hoffman
Nickname: Abri
Jules, die ou by Nissan het my verwys na 'n plek in Pretoria wat dit vir my kan doen. Dit sou waarskynlik bietjie goedkoper gewees het maar ek het nie tyd om daar uit te kom nie. Dan moet ek ook se dat en nie dink R284 is roof nie. Sou hierdie pypie nou R600 of meer wees sou ek 'n plan gemaak het.
2013 FJ Cruiser
"Jack Russel"
Abri Hoffman
Nickname: Abri
After 5 weeks I received the requested part and installed. Oh how nice it is to drive with a fully functioning clutch again.
Nissan came to the party after me fighting with everybody in sight and telephonic reach. They contacted me every second day to give progress updates. :thumbup:
2013 FJ Cruiser
"Jack Russel"
duckitt
Full Name: Charles
Nickname: Charles
Home Town: Cape Town
Current 4x4: 4.8 GQ Patrol 4x4 & 1996 (4.8) SGL GU was n 4.2 Petrol
Post by duckitt »
Jy kan by goeihoop spares in brakenvel die pyp laat maak
vir 175. Daai manne hou self die egte nissan altenators net
In n ander boks aan vir amper niks
Charles Duckitt
Duckitt Security Services
online7584692@telkomsa.net
0837085003
0219766432
Abri Hoffman
Nickname: Abri
Duckit, as ek geweet het dit gaan so mission wees het ek een laat opmaak. Aanvanklik sou dit binne 'n aanvaarbare tyd hier gewees het en ek het nie tyd gehad om by 'n plek uit te kom wat dit kon opmaak nie.
Nou weet ek beter :wink:
2013 FJ Cruiser
"Jack Russel"
