MAF Sensor replaced
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
MAF Sensor replaced
Post by Stefan »
Earlier this year my Patrol started feeling decidedly sluggish, one could feel that there was no power. After a long search for the culprit (and the very necessary replacement of the turbo), I eventually took it to Koos Swanepoel Developments in Stikland where they put it on the Dyno and within half an hour they told me that the MAF sensor was faulty.
The sensor is supposed to vary between 0 and 5V depending on the airflow and mine was stuck on 1V.
I replaced the MAF sensor with a Nissan part (~R2k VAT incl) and took it back to them to ensure that the boost hasn't been turned up too high etc.
This is the result:
Now, Stefan = :blonde: Patroller :woo:
Re: MAF Sensor replaced
Ek is bly alles gaan nou goed! :thumbup:
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Current 4x4: 2005 4.8 GRX
Been thanked: 102 times
Post by bogeyman »
Teen R2k vir die sensor is dit R35/kw en R16/ NM .
Beter as n superchip! Bargain.....
Mooi nou kan jou olie burner weer oordentlik patroleer ......bly jy het reggekom :thumbup:
wat seg de EGT nou Stefan ??
