Oxygen Sensors, MAF sensor?
- Blitzpatrollie
- Full Name: Gavin Kukard
- Nickname: Gavin
- Home Town: Croc Valley Conservancy, Nelspruit
- Current 4x4: 2003 Nissan Patrol 4.8 GRX Auto (Gold)
- Been thanked: 9 times
Hey guys, how do I test these sensors to see if theyre reading properly?? As I have it, and oxygen sensor has a life span of around 100 000km, and in my patrol (204000km), there is no records of ever having new sensors put in. Vehicle is overfuelling as I can smell petrol on my hand when held at exhaust, and I'm using 20.2l/100km. Exhaust is black also. Dealer said its plugs, but the plugs are platinum type and 3000km old. Clearly the dealers don't know very much...
Hope someone can help!! Need to know if I must order new sensors :)
Thanks!
Gavin
Thanks!
Gavin
Re: Oxygen Sensors, MAF sensor?
Hi Gav
Heyj Bru -- with unleaded fuel exhozzt IS black .. mos ?
Grootseun will pop in sometime - OR you should PM him for info on how to test for those functionalities
[smaak my jy moet wegbly van jou dealer af .. hy roof jou en jy issi eens blind nie]
Do a 4 gas test and take it to graham he has the tool to check and test the sensors
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Gavin, is that 20.2 l/100km on the open road or in town? If the latter, then it is pretty much par for the course. Do you have tyres with a larger diameter than standard? If so, you must remember that this fact will mean that your odometer under-reads, which must be adjusted for in your fuel consumption calculations.
- Blitzpatrollie
- Nickname: Gavin
@Kagiso Haha!! Jy kanie nie "mos" nie!! Ek ry al afgelope 10 jaar net diesels, het laaaaaankal vergeet hoe die petrols operate, maar wat ek wel kan onthou is dat die exhaust gryserig moet brand. Swart is teken van overfuel? Wel, nie seker nie, maar ek ruik petrol bd exhaust en ek vermoed dit moet nie so wees nie? :))
@Tinus Graham is mos in JHB nie waar nie? Wil jy dan nou he ek moet R10 000-00 se petrol uitry om R10-00 op 'n tenk te spaar!?
Eks in Nelspruit. Maar gaan so twee keer 'n jaar (twee keer te veel) Pta toe, so sal dalk met my volgende trip 'n draai maak by hom
@Gerrit Daai verbruik was 95% oop pad, alhoewel ek bergpas gery het vir so 45km op, maar het weer afgekom ook so dit behoort mos uit te balanseer?? Ja hyt 119lt gevat, toe ry ek 602km tot hy LEEG was, toe vat hy 122lt. Terloops, terwyl ek opry Steiltes toe hier in Nelspruit, brand my reserve liggie, en toe ek amper bo kom toe splutter en vrek hy amper, hoe klein is daai reserve!?
- Blitzpatrollie
- Nickname: Gavin
@Gerrit Ek het tans 275/70/16s op, maar het 'n stel 285/75/16's bestel, maar werk my myle op die GPS se lesing uit.
- Jorrie
- Full Name: Jacobus Jordaan
- Nickname: Jorrie
- Has thanked: 184 times
- Been thanked: 165 times
As others have said: Tyre size is an issue. Secondly, don't expect a grey exhaust with the unleaded fuel we are now using. Your fuel consumption seems to be on par.
- Has thanked: 1130 times
- Been thanked: 1044 times
Ek kan beaam dat grys uitlaatpype nou so uit is soos boerewors in 'n hondehok. Dit was die lood neerslag wat daardie grys veroorsaak het.
Die petrol-rek, is dit terwyl die enjin koud is, of reeds op temperatuur. Dis normaal as die enjin koud is.
Die brandstof-verbruik staan op die deur geskryf, deal with it. Soos vriend JG altyd gese het, jy kan nie 'n olifant op 'n renperd se dieet onderhou nie.
Dit kan egter die moeite werd wees om die MAF skoon te maak, en ook om die brandstofpomp se druk te laat toets.
Stel jou tydreeling 10 grade stadiger en vergroot die vonkprop gapings na 1,2 MM
Retard timong by 10 degrees and open the spark plug gaps to1,2 mm
Offe neeeeeee wag -- dies vir 1980 DATSUN met vergasser
- Blitzpatrollie
- Nickname: Gavin
Haha!! Wou nou net se... Ek vermoed my siel word nou bietjie uitgetrek hier...
Se my gou, die MAF sensor, kan ek Electrokleen (Contact Spray) gebruik om dit skoon te spuit?
