Autobox clonk
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Autobox clonk
Post by Clem »
Guys, when I've been driving at speed and coast to a stop at an open road intersection, just before I come to a dead stop, there is a single clonk as the box shifts down; ie a slightly harsh downshift. Is that normal? A new 4.8 GRX.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: Autobox clonk
Post by David »
Hi Clem.
Mine also did it from day one. I think it is related to the idling speed and it's behavior changes with your driving style.
Try coasting in slowly before you come to a stop.
Check out this link: Thud
You can also try resetting the TCU by unplugging it over-night and by adjusting your timing to 10 degrees advance as yours are more than likely still a factory stock 5 degrees.
Must say it is quite an unrefined clunk :surprised:
Let us know if that helps :thumbup:
Clem
Nickname: Clem
Re: Autobox clonk
Post by Clem »
David wrote:Hi Clem.
Many thanks for the input David. I'm not sure about the aircon thing - will monitor but I think in my case I did not have it on, but I could be mistaken. The TCU is the transmission control unit? Maybe I can just disconnect the man in batty overnight instead? 5 degrees advance on the engine timing? If that's all it has I probably really should get it changed - obviously set to cope with really low grade fuel (?).
David
Nickname: David
Re: Autobox clonk
Post by David »
You can do so but it is actually very easy to disconnect the TCU.
Stick your head under the dash drivers side. It is mounted below the radio. It has a lever that flips open and then the connections can be removed. :thumbup:
If you disconnect the battery your radio will ask for a code and you will have to reset all the stations :doh:
David
Clem
Nickname: Clem
Re: Autobox clonk
Post by Clem »
Thank you David.
