boutroswine wrote:
1. What kind of Fuel consumption can I expect for this Patrol doing open road @ +_ 110 KM ? Ek neem aan as dit n 2001 model is dat jy n 4.5 het. As ek met my 4.5 die spoed ry, kry ek so 6-6.5 km/l. Dit hang wel af of jy n roof rack ophet met al die dinge wat daar op kom soos roof top tent. Bande maak ook n verskil. Ek het 267/75 op want ek het die kar met dit gekry. Sal seker as ek moet vervang groter gaan.
2.I had problem were the Battery power just started to drop during a short trip to Town. It caused the engine to stop. I had the patrol taken to a Auto elec who told me it was just a very flat battery which they recharged. On the trip back home it started to drain power again.No light came on for the altenator so why does it not charge the Battery ?
3. What is the best Fuel Type (Petrol Leaded or not ) for this engine as well as oil.Living on the coast. http://patrol4x4.co.za/viewtopic.php?f=45&t=1557
4.I do have massive oversize Kumo Tyres on the vechile which I will have to change to help with Fuel consumption. Any advice on whats best ?
5. Any problems that I should look out for on this spesific Patrol . It has 140 000km on the clock Ek en n paar ander manne op die forum het ons petrol pompe vervang. Daar is blykbaar n probleem met die 4.5 patrol en cruiser pomp. Dit maak n groot verskil in krag. Jy kan dit gerus doen. Die diff-lock op die patrols kan ook probleme veroorsaak. Maak seker dit werk. Daar is redelik inligting op die forum daaroor.
I would appreciate all the advice I can get.
rgds
Pieter
Boutroswine's Patrol
- Marino4x4
- Nickname: Marino4x4
- Home Town: Bloemfontein
- Current 4x4: Nissan Patrol
- Has thanked: 17 times
- Been thanked: 87 times
- Carel
- Full Name: Carel Vos
- Nickname: Carel
- Home Town: Germiston
- Current 4x4: 84 Safari
2001 Patrol 4.5 GRX - Home Language: Afrikaans
- Been thanked: 10 times
Re: Boutroswine's Patrol
Check the starter motor. I've heard of a few that packed up.
- Chris Skinner
- Full Name: Chris Skinner
- Nickname: Chris
- Has thanked: 10 times
- Been thanked: 53 times
Welcome to the forum Pieter
Battery/Alternator Problem - I had same problem soon after buying my previous 4.5 Patrol. One day while driving with lights and aircon the engine just died. I put off teh aircon and lights and engine went back to normal. A deeper investigation showed that whenever I put on something that used electricity, the engine died. There were no warniing lights shopwing battery or alternator problem. I was actually towing my boat down to Richardsbay at the time and had 2 spare batteries on board - so I changed over batteries and continued to Ermelo where I put in the third battery, and had the other two rapid charged while having breakfast. Anyway - I got to RBay eventually and had a new Bosch Alternator fitted. So, yes there is a failure mode where the Alternator packs up and you see no warning lights. Obviously if all this is happenning with having a weak/old battery at same time, the symptoms can be confusing - I would start by having the alternator tested, and if OK then replacing the battery.
- Full Name: Ian Temperley
- Been thanked: 92 times
Just done about 600km in my 4500 pburg to orpen in knp worked it out at 6.2 km per L fully loaded with a rr but nothing on it ( wife is here so we have to have proper beds no RTT for her) ok got to go ratal is raiding the kitchen outside!
- Newbie
- Full Name: Pieter Meiring
- Nickname: Pieter
- Home Town: Bot Rivier
- Current 4x4: 2001 Patrol 4.5 EFi GRX - Auto - Petrol
Thanks for all advice Guys. The sad part is that I got the Patrol 4 x Days before i left for my offshore Rotation so can't wait to get home. Not sure who I will hug first - Wife or Patrol !!
rgds
Pieter
rgds
Pieter
- Jorrie
- Full Name: Jacobus Jordaan
- Nickname: Jorrie
- Has thanked: 184 times
- Been thanked: 165 times
By the time you return the wife will be more in love with the Patrol than with you.boutroswine wrote:Thanks for all advice Guys. The sad part is that I got the Patrol 4 x Days before i left for my offshore Rotation so can't wait to get home. Not sure who I will hug first - Wife or Patrol !!
rgds
Pieter![]()
