Is there any reason why those pumps mechanics use to remove oil can't be used on the 4.8 Auto's box?
It's a suction pump works on vacuum and some have compressors. Is there a space limitation as to why is can't be used?
Changing AUTO gearbox oil
Re: Changing AUTO gearbox oil
Roy there is a filler cap on the gearbox as far as I know also you can buy a dipstick if you want to .
just note that you must only use the ones from the stealers graham did mine at 120000
