Radiator, urgent
johannes.dieterich
Full Name: Johannes Dieterich
Nickname: Joggel
Current 4x4: Patrol 4.5l
Home Language: English/German
Radiator, urgent
Post by johannes.dieterich »
I am urgently looking for a newly imported or reasonably refurbished radiator for my Y 61, 4.5l petrol, year 2001.
The original one is apparently 14.000 Rand which I can't afford.
I need it as a matter of urgency. Any advise appreciated.
Johannes
Re: Radiator, urgent
Tombo radiators in jhb hulle het een vir my vriend roelf gebou alles nuwe parte het 2 dae gevat en was omtrent 2700 rand graham het hom ingesit.give me a call or pm me your no mine is zero8 three 29seven8oone3
johannes.dieterich
Nickname: Joggel
Tinus lotz wrote:Tombo radiators in jhb hulle het een vir my vriend roelf gebou alles nuwe parte het 2 dae gevat en was omtrent 2700 rand graham het hom ingesit.give me a call or pm me your no mine is zero8 three 29seven8oone3
You are really a star, Tinus! I owe you one.
Took the old radiator to Tombo this morning. They promised to make me an new one out of alluminium by Friday. 3 grands plus VAT. That's the inflation. Ordered one for Graham as well.
You saved me thousands of Rand!
Will stay in touch.
Johannes
:thumbup: :thumbup:
Wat is die gevoel oor aluminium core verkoelers?
Ek moet binnekort my 4.5 se verkoeler vervang. Verkoeler is redelik verstop.
740 BMW se radiator werk ook .. so ongeveer R2000.oo
Aluminium verkoel baie beter as ander metale .. fisika feit
Dankie oomoie
Enige elektrolitiese effekte?
Jorrie, die oorspronklikke radiator is Aluminium. Die silinder-kop ook. Elektrolise is nie 'n probleem nie, net roes. Sorg dus dat jy die regte anti-freeze reg gebruik.
Koper verkoelers het net twee voordele:
hulle corrodeer stadiger (veral by die see) en hulle is maklikker om reg te maak.
Graham hou gewoonlik n paar in vooraad
Dit is meer belangrik dat die mounting punte oplyn en die rubbers op regte plek is .ek dink hulle kos so 3k nou .ek weet van so 5 4.5 patrols wat met hulle loop en dit werk baie mooi
Dankie Tinus. Ek was gister by Graham.
