Light switch
Has thanked: 193 times
Been thanked: 275 times
Light switch
It seems the previous owner pot "stronger" lightbulbs in the Troll and because he did not fit relays the "light switch" situated under the steering wheel (covers covering steering colum) has now burnt out and the Troll has no lights.
Firstly is this possible :helpsign:
Secondly where can I get one of these light switches or is it a stealer item only?
Tx
Re: Light switch
First change the lights to something that will not burn your switch or fit a relay and yes very posible and yes speak to the stealers
Re: Light switch
Ok so its called the "dim and bright" switch, apparently only available from stealers :doh: - awaiting price.
Yep will be getting a relay per light installed with the new switch to ensure this does not happen again :thumbup:
Re: Light switch
I seem to recall something about the Nissan Sentra parts being compatable..... but not entirely sure
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Re: Light switch
Post by Bruin Beer »
Cedric,
Somebody also refered to old Skyline part compatibility. Can't remember what that was for.
Good luck Offroadbicker
You should be able to fit a seperate manual hand switch to replace the existing dim/bright.
Bruin Beer
Re: Light switch
Bruin Beer wrote:You should be able to fit a seperate manual hand switch to replace the existing dim/bright.
Bruin Beer
Tx, will ask the auto lec about this, as if I poke around nothing will be working :redface:
Re: Light switch
Yes you may be right there, it could be the skyline part. I also just cant quite remember exactly
Re: Light switch
So they cant get the part using my Vin no :doh: , but trying Y60 4.2 SGL they came up with R823.00 for a switch :thumbdown:
When is Grant back from holiday? and what is his number? I am sure he can do better than that :oldtimer:
Re: Light switch
You mean Graham, I presume..... :rolling:
Re: Light switch
QQQ
Maybe I should stop drinking at work :doh:
