My Patrol's dashboard started developing bubbles over the December holidays.
Nissan in Centurion was most helpful and arranged for a replacement at 50% of cost. This was done in February.
Last Saturday evening I had to set the aircon to de-fog the windscreen. This function has not been used before, after the dash was replaced.
Now the aircon vents appears "stuck". Everything appears to work fine, except, no matter how one sets it, no air comes from the "main" vents in the middle and on the sides of the dashboard, it all seems to be directed to the defogging vents underneath the windscreen.
I can only speculate that it has something to do with the dash replacement.
Any ideas? I hope there is a solution other than opening up everything again.
Airvent problem after dash replacement
- Wynvat
- Full Name: Gerhard van Rhyn
- Nickname: Wynvat
- Current 4x4: Patrol 4.8 GRX Y61 GU(4)
- Been thanked: 1 time
- Full Name: Jacques Strauss
- Nickname: NISMOnator
- Current 4x4: 2007 Nissan Patrol 4.8 GRX
- Has thanked: 19 times
- Been thanked: 3 times
Re: Airvent problem after dash replacement
I would suggest taking it back to the dealer to fix what they broke?
sounds like one of the vales are not connected >>>>>>>>>>.......take it back
- Wynvat
- Nickname: Wynvat
Dankie manne.
Laat weet wat die uit einde is!
