Get more "up" flex - PeterC as reference
dieselfan
Full Name: Roy Markham
Nickname: Roy
Post by dieselfan »
I was watching some footage of PeterC's car on an axle twister and noticed at the Patrol day they didn't all behave the same. Although the wheel drops on some, the opposite wheel wouldn't go into the wheel arch as much even though it needed to. Peter's was perfect.
Seen loads of Youtube too and many patrols although high, the wheels don't flex / go into the arch is it too heavy of a coil?
What is the key?
Has thanked: 1136 times
Been thanked: 1047 times
Re: Get more "up" flex - PeterC as reference
Roy, not sure which cars you compared with, but some of the contributing factors can be:
1) The GQ has a lower arch than the GU, thus the wheels appear to go in deeper on a GQ.
2) I have bigger wheels than most guys.
3) The droop on the other side efectively pushes the high side even higher.
4) A body lift will lift the arch away, reducing the appearance of wheel lift.
But yes, harder springs will also effect it. Unfortunately I don't know what springs are in mine...
dieselfan
Nickname: Roy
Post by dieselfan »
Actually Peter I follow an OZ Video Magazine and they were comparing new vs old, cruisers 100 vs 200, d1 vs d3, gq vs gu through the same obstacles water, mud, rocks etc.
Through many the GQ = GU but overall they reckon GQ > GU. I must check the details, I do remember them specifically stating better composure.
Roy, give us a link?
But the GQ and GU are extremely similar in terms of suspension setup. In terms of upward travel, they use exactly the same bump-stop rubbers, and the aftermarket suspension suppliers (particularly OME who publish this information) use the same springs and shocks for both. The only difference I can think of that may have this affect is the anti-roll bars.
dieselfan
Nickname: Roy
Post by dieselfan »
They have a youtube channel it's called 4wdmonthly
http://www.youtube.com/feed/UCsaP2BBNaydWknvYfDBIvww
They have the most interesting topics and very unlike our SA mags. Just passionate outdoor stuff. Loads of patrol tho :blonde:
Old vs New
There's a series of the old vs new not just the one link above. Unfortuantely you need to buy the DVD to get the details of WHY one was better than the other the youtube clips are mostly teasers.
