Re-wiring my Winch
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Re-wiring my Winch
Post by Chris Skinner »
Hi Guys
Anyone got some advice on what is best electric cable to use for re-wiring my winch.
I am upgrading the motor on my warn M8000 (which smoked on me) with a new 6hp motor as used on the 9.5xp winch, which I sourced on Amazon for half the local price. The stronger motor fits perfectly apparently turns the M8000 into a serious winch. It pulls a few more amps though.
Current wiring is a bit tired and has some corrosion, so I am considering redoing it.
I was thinking of trying to find some 70sqmm cable cable with capacity up to 600amps with some good connectors fitted. :eureka:
Re: Re-wiring my Winch
I think it is a good ideato fit a cut-out switch (as found at the motor racing shops) in the engine bay. This firstly forces you to open the bonnet, but also apparently protects the solenoid in water crossings?
firessafari
Full Name: Johan van Vuuren
Nickname: Johan
Current 4x4: Safari s/w
Been thanked: 7 times
Post by firessafari »
Welding cable is the best. different amp ratings available, visit your welding supply store.
Johan
Chris Skinner
Nickname: Chris
Hi Tinus - thanks for the call
See the 2 winch specs for the 9.5XP and the M8000 below.
I am fitting the XP's 6hp motor to my M8000.
The M8000 has a larger gear ratio than the xp (216 vs 156) - this means my new spec winch (M8000 with xp motor) will be slightly slower than the xp, but more power and possibly slightly less amps than the std xp (if my logic is correct).
Anyway - I believe it turns the M8000 into a monster winch, for the price of new motor! according to some posts I read on the internet. This should mean that I do not have to use a snatch block in future, when pulling boat onto trailer.
Any advice welcome!
9.5XP SPECS/PART NUMBER
Winch model: 9.5xp
Part number: 86500 (wire rope, CE)
Rated line pull: 9,500 lbs., (4310 kgs.) single-line
Motor: 12V 6 hp (4.48kw), High output parallel series wound
Electrical controls: Contactor
Remote controls: Remote switch, 12' (3.7m) lead and
Geartrain: 3-stage planetary
Gear ratio: 156:1
Clutch (freespooling): Sliding ring gear
Brake: Automatic direct drive cone
Rope: Steel - 100', 5/16" diameter (30m, 8mm diam.)
Fairlead: roller fairlead
Recommended battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72" (1.83m)
Finish: High-gloss powder coat over primer undercoating
Drum diameter/Length: 2.5"/9.0" (6.4cm/23cm)
Weight: 87 lbs. (39.5 kgs)
9,5 XP 12V DC PERFORMANCE SPECS
Line Pull Line Speed Motor Pull by layer
Lbs.(Kgs.) FT./min(M/min.) Current layer/Lbs(Kgs.)
0 38 (11.6) 70 amps 1/9500 (4313)
2000 (910) 16.8 (5.1) 175 amps 2/8650 (4927)
4000 (1810) 12.8 (3.9) 262 amps 3/7920 (3595)
6000 (2720) 10.1 (3.1) 335 amps 4/7400 (3359)
8000 (3630) 8.8 (2.7) 425 amps 5/6940 (3150)
9500 (4310) 7.6 (2.3) 480 amps
M8000 SPECS/PART NUMBERS
Winch model: M8000
Part number: 26502 (wire rope, 12V)
Part Number: 88502 (wire rope, 12V, CE, International sales only)
Part Number: 265032 (wire rope, 24V)
Rated line pull: 8,000 lbs., (3630 kgs.) single-line
Motor: Series Wound, 12V 4.8 hp, 24V 2.1 hp,
Remote Control: Remote switch, 12' (3.7m) lead
Gear train: 3-Stage Planetary
Gear ratio: 216:1
Brake: Automatic mechanical cone
Weight: 74 lbs. (34 kgs)
Rope: Steel -- 100', 5/16" diam. (30m, 8mm diam.)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Finish: Argent gray powder coat
M8000 12V DC PERFORMANCE SPECS
0 30.2 (9.20) 80 amps 1/8000 (3629)
2000 (910) 14.2 (4.33) 200 amps 2/7280 (3302)
4000 (1810) 9.9 (3.02) 285 amps 3/6670 (3026)
6000 (2720) 7.3 (2.22) 350 amps 4/6230 (2826)
8000 (3630) 4.8 (1.46) 435 amps
Assuming the same drum diameter and similar friction losses, that could give you a 13 000lb winch!
Make sure your cable can handle that. :mytwocents:
Chris Skinner
Nickname: Chris
Yes, the basic dimensions etc are same for M8000 and XP. If I look at the parts lists on Warn website all the winches <10000lb are pretty much the same with only different motor specs and gear ratios (I wonder why such big price differences then :think:)
I also have a 10mm synthetic rope on the winch that can pull up to 18000lb :thumbup:
Thanks for the confirmation Peter - I cant wait to pull the boat and see the difference.
Return to “21. DIY Projects”
