Rear Door Mod
Ratau
Full Name: Danie Terblanche
Nickname: Danie
Current 4x4: 2000 Nissan Patrol 4.2 diesel / DIY Turbo Conversion.
485 Nm@1300Rpm NA
Patrol rear door mod.
Post by Ratau »
Another small but practical modification that could make life a little easer.
http://www.4x4equip.com.au/listProduct/ ... +Extension
Danie
Live while you’re alive!
G-MAN
Full Name: A.G.HOLMES
Nickname: G-MAN
Home Language: Engels
Been thanked: 9 times
Re: Patrol rear door mod.
Post by G-MAN »
Ok. So who is gonna make some? :wink:
Sucks Gas and Hauls Ass!
Pieter du Toit
Nickname: PJ of ook Whitey
Home Town: Welgemoed
Been thanked: 6 times
Rear Door Mod
Post by Pieter du Toit »
Hi All Patrollers,
I decided to get one of those door extension hinges for the rear door advertised on the Aussie web - and it arrived yesterday!!! :clap: Yes it woks out a bit expensive - but I thought what the hell - got nothing to lose!! And what a pleasure it is to open that rear door now :thumbup: - I have a fridge slide in the left rear, and it always scratches the leather on the inside of the door :thumbdown: - from there the piece of sheet metal you will see on the photos. This is what it looked like before the mod:
And this is after the mod - check the difference!!!
Looks great hey - maybe we must get Nissan SA to bring these things in - maybe it will work out cheaper then!! :wink:
Moderator's Note: Duplicate posts deleted and pictures fixed (hope I got them in the intended order)
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
Pieter du Toit
Re: Rear Door Mod
To the moderator who had to fix up my mess (once again!!) - Thank you - don't know what I am doing wrong but I just don't seem to get it right!!
Some day some where ....in the distant future I will be there as well....
Pieter du Toit
MUFASA
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Re: Rear Door Mod
Post by Gerrit Loubser »
Pieter, could you perhaps post pictures of the actual hinges?
Current 4x4: None
Re: Rear Door Mod
Pieter du Toit wrote:don't know what I am doing wrong but I just don't seem to get it right!!
Pieter, the problem was that you actually used the address of the album instead of to the individual pictures. The address of the album looks like this:
http://www.patrol4x4.co.za/gallery/albu ... lbum_id=49
The best way of obtaining the address of an individual picture in an album is to click on the thumbnail so that the full size image opens and then to right click on the full size and then go to "Properties" to get the image address, which looks something like this:
http://www.patrol4x4.co.za/gallery/imag ... age_id=255
This address can then be inserted in between the [ Img ] and [ /Img ] codes to have the image displayed in your post.
A common mistake is to right click on the thumbnail image and then use its address. This leads to small thumbnail images being displayed instead of the fullsize ones intended. The thumbnail's address looks like this:
Notice the "mode=thumbnail&" part in the address, which distinguishes it from the address of the fullsize image.
Pieter du Toit
Re: Rear Door Mod
Gerrit,
Ok thanks for that technical explanation - even me as a blondie understood it!!! :thumbup: Sorry about the mess you had to fix though :redface:
I can kick my own bud that I did not photograph the hinge before attaching it to the body - but I actually read about it somewhere here on our forum. Go to www.4x4equip.com.au - you will get pictures there as well. But it is a piece of pie to fit - even for a blondie like me!! :biggrin:
I will remove it at a later stage and then post (try!!??) a picture or 2 of it again.
Rgards
Pieter du Toit
MUFASA
G-MAN
Nickname: G-MAN
Re: Rear Door Mod
Post by G-MAN »
So how much was it? :surprised:
Re: Rear Door Mod
Can't we "local maufacture"it?
AJ Dup
Full Name: Abraham Johannes Du Plooy
Nickname: A.J.
Current 4x4: 4.8l Patrol GL
Home Language: Afr
Re: Rear Door Mod
Post by AJ Dup »
Does this door extension hinge carry any weight because I just unbolt it on a trip and make sure with modified rubber door stoppers that the door doesn’t open too far to bend it?
4.8l GL Patrol
