Oiling your box
Oiling your box
Yesterday evening I frustrated myself endlessly trying to put new oil in my trollie's gearbox.
I don't know if it's just me, but it seems the modern gearbox oil bottles are really badly made. Every time I squeezed the bottle to get the oil out, I got an armfull of oil as the oil squirted past the tube instead of through it, and each time I made a wrong move the tube pulled out of the bottle.
As I was removing the second bottle from the gearbox, the tube pulled out of the bottle and promptly fell into the gearbox.
To retrieve it, I had to pull the drainplug (and thus waste two bottles of oil), and fortunately I then managed to hook it over the hole with a bent piece of bailing wire and could then drag it out with long-nosed pliers, but by that time I had soiled several pairs of underpants with thoughts of having to pull the gearbox...
Anyway, I think that I have found the answer. I stopped by the local model shop on the way home this afternoon, and R150 later I walked away with a hand-crancked pump such as the modelers use to pump nitro fuel into their planes and cars, and a metre of pipe. Upon getting home I then heated a bottle of gearbox oil by putting it in hot water, and the pump pumps it beautifully!
Just thought I'd share the tip.
Re: Oiling your box
Mooi man! :thumbup:
Traveler
Full Name: Heinrich Stoltz
Nickname: Traveler
Home Town: Springs
Current 4x4: Patrol 3.0 GL,
Re: Oiling your box
Post by Traveler »
Peter, that is a brilliant solution. I have one of those pumps, and since I only fly electric these days, it is sitting idle. :eureka: :eureka: :thumbup: :thumbup:
I've had that experience that you mentioned with these stupid little bottles you just manage to press to pieces.
Re: Oiling your box
Slim plan Piet :thumbup:
Has thanked: 189 times
Been thanked: 270 times
Re: Oiling your box
Nou weet ons waantoe om ons Trol's te vat vir hulle volged ratkas olie vervanging :tease:
Rudolph
Nickname: Rudolph
Home Town: Port Alfred
Has thanked: 107 times
Been thanked: 36 times
Re: Oiling your box
Post by Rudolph »
Hi Peter,
Boer maak 'n plan daar! :salute: Watter tipe olie het jy die keer gebruik, weer die Castrol BOT130? Was dit weer tyd gewees om die olie te ruil of het jy geruil vir ander redes?
Cheers,
Rudolph
Been thanked: 473 times
Re: Oiling your box
:rolling: :rolling: .... Peter.... I know exactly how you feel....I did mine with much swearing and then started having visions of oil wrestling..... but moving on..... :rolling: :rolling:
I landed up feeding a fairly large diameter clear hose from bonnet height in the engine bay down into the box, and poured the oil through a funnel into the pipe...... took a loooooooooong time to feed into the box.... and then had the battle to take the pipe out the box with the minimal spillage of oil still in the pipe....not one of my best days..... :lol:
Stefaansie
Full Name: Andre Vorster
Nickname: André
Home Town: Benoni
Been thanked: 9 times
Re: Oiling your box
Post by Stefaansie »
ricster wrote::rolling: :rolling: .... Peter.... I know exactly how you feel....I did mine with much swearing and then started having visions of oil wrestling..... but moving on..... :rolling: :rolling:
Hmm,
No Offense, but I would definitely NOT want to watch you oil wrestle.... :rolling: :rolling: :rolling: :rolling:
Peter,
Great advice. Ek dink ekke moet ook een of ander tyd die GB olie ruil. Watter olie sal die beste wees?
Behoord die féncy Sintetiese olie die Low down torque/revs Rumble bietjie stiller te maak?
'96 SGL-D PATROL (GQ)
ECHO 3
'07 SUZUKI BOULEVARD 1800
'06 YAMAHA 700 RAPTOR
Re: Oiling your box
Rudolph wrote:Hi Peter,
Cheers,
Rudolph
BOT 130M is nou vervang in Castrol se reeks deur Syntrans Multivehicle. Ek het dit gebruik. Teen omtrent 25k km was dit oortyd as jy volgens die Y60 sy specs gaan (20k km) maar nog nie naastenby die Y61 se 100k km nie, en dis veronderstel om dieselfde ratkas te wees. Die grootste rede is egter dat 5de rat se syncro begin deurgly as die kar warm is, en ek het gedink dis dalk die olie, maar hy doen dit nog steeds. Ek sal bly wees as Gerrit dalk vir ons kan verduidelik of sy probleem dieselfde was.
marakasmalan
Full Name: Marnus Malan
Nickname: marakasmalan
Current 4x4: '94 Patrol SGL
Been thanked: 16 times
Re: Oiling your box
Post by marakasmalan »
I usually wait for my brother to visit before I attemp these jobbies, but certainly a very usefull and cost effective solution!
@Peter, thanks for another good contribution - we should club together and get you a PEP Stores voucher for those soiled underpants.
@Traveler, if your pump that is sitting idle is a problem I'll take it off ou hands.. :biggrin:
Lastly, if you require sawdust or wood shavings for cleaning up, let me know I can sell you cheap-cheap (as I am not allowed to take anything out of the company yard, it must be sold for at least some value to be able to create the release/delivery note...)
