How big are my tanks suppose to be?
- Full Name: Barto de Koning
- Nickname: Zantus
- Home Town: Port Elizabeth
- Current 4x4: '01 4.5 GU & '91 4.2D GQ
- Has thanked: 3 times
- Been thanked: 5 times
From the info I had, the tanks in my 2001 4.5GRX should be about a main tank of about 90-95 litres and the sub tank about 35-40 litres.
On Friday night, filling up both tanks for the first time, the main tank took 121 litres and the sub tank took 36 litres....it was close to completely empty, actually started cutting out around a long turn close to the filling station.
Was a +/-120 litre main tank common for the year model?
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Re: How big are my tanks suppose to be?
That does not sound standard to me. I think the standard capacities are 95 and 40 as you said. Mine certainly was and that was what the owners manual also stated as far as I remember.
My 4.8 also takes 90 and 40 I think you have a longrangge main or the pump saw you coming
nothen ofroad makes a 120 lter main tank put n pic let's see
die pompjoggie het sy ei ekan ook volgemaak ???
- Nickname: Zantus
Hmm, I'll have a look underneath, sounds like it has a long range main tank.
- Full Name: Wilhelm van Rooyen
- Nickname: Wilhelm
- Home Town: Secunda
- Current 4x4: The 4.5 Turbo
SWAMBO - 2007 Jimny - Home Language: Afrikaans
- Has thanked: 66 times
- Been thanked: 93 times
I have a 1999 GRX.
Main tank : 120 l
Sub tank: 40 l
Seems pretty normal to me :)
Main tank : 120 l
Sub tank: 40 l
The 4.5 Turbo
The 4.5 Turbo
- Full Name: Rob Edeling
- Nickname: Rob
- Current 4x4: 2001 4500GRX Patrol
My 2001 4,5 GRx is also 90 and 40 lt
I agree, Check the pump, I once managed at a Garage in Inhambane to get get 32lt into 20 lt Jerry can.
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Been thanked: 26 times
Gents,
Could be that the main tank has been replaced with the Excel tank. Capacity is 136 lt but I get around a 128 lt in. Have a look under the back and see if the tank still has its protection plate. Also if it is SS, it is an aftermarket tank.
- Has thanked: 1136 times
- Been thanked: 1047 times
Sounds like an aftermarket tank to me too.
The easiest way to recognize it is probably that the standard tank fits between the chassis corner pieces, while the high-capacity tanks usually extend under the chassis corner pieces.
Also, the standard tank has rounded edges and a thin protection plate, while the aftermarket tanks are usually square-cornered and without protection.
- Full Name: Roy Markham
- Nickname: Roy
- Current 4x4: Patrol 4.8
- Been thanked: 2 times
I read recently about the newly proposed compressed fuel tanks. It's obviously not recommended for Non Patrol's due to safety hazards. Maybe you lucky and got a prototype
Fill up and see how long your gauge stays full - if around 600km then yes you have the new type. This only works on petrol as diesel kept on exploding under compression and then your gauge won't work.
Or
Peter could be correct...
Or
