WHEEL ALIGNMENT
- BABELAAS
- Full Name: LOWE
- Nickname: MARC
- Home Town: BRONKHORSTSPRUIT
- Current 4x4: 2015 Navara 4X4
- Home Language: ENGLISH
- Been thanked: 3 times
WHEEL ALIGNMENT
does anyone know of a good wheel alignment place in Centurion?
I want to take my Hardbody in for full alignment, castor, camber , ride heights etc. It has on a set of BFG's that have done 70k and are showing wear on the sides and I want to get the alignment sorted before fitting new BFG's.
Most places just do the Toe in/out and call it wheel alignment!!!!
BABELAAS
2015 Navara 4X4
2015 Navara 4X4
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Re: WHEEL ALIGNMENT
Contact,
Hein or Patric at Auto wiel 012 6535470
Great guys and always willing to go the extra mile.
- Been thanked: 473 times
Re: WHEEL ALIGNMENT
From what I understand there isn't much adjustment that can be done on a Patrol, due to there being a solid front axle. Castor can as far as I know only be adjusted by fitting different offset bushes. Camber is a fixed thing that cannot be adjusted. Ride height adjustment, only new or different coil springs will help here, and that only leaves toe in/out adjustment available. They can fit a spacer on the front left ( I think its called a Panhard arm ) metal arm where it is bolted to the chassis, that houses the castor bushes, a little forward to assist with the "pull to the left issue. Mine was done at Dunlop Zone in Alberton and it did help a little.
Please correct me if i'm wrong.....
- Marino4x4
- Nickname: Marino4x4
- Home Town: Bloemfontein
- Current 4x4: Nissan Patrol
- Has thanked: 17 times
- Been thanked: 87 times
Re: WHEEL ALIGNMENT
Hi Cedric
I think it is his Hardbody he wants to do the wheel alignment on, not the Patrol.
Re: WHEEL ALIGNMENT
Oh...look there.... clear as mud it says " I want to take my hardbody...."
Me and my blonde hair..... again...!!!
- BABELAAS
- Full Name: LOWE
- Nickname: MARC
Re: WHEEL ALIGNMENT
Hi All,
Thanks for the info, I will give them a try. I spoke to them on the phone and they seem to know there stuff.
BABELAAS
2015 Navara 4X4
2015 Navara 4X4
- BABELAAS
- Full Name: LOWE
- Nickname: MARC
Re: WHEEL ALIGNMENT
Hi Guys,
Thanks for the info, took the hardbody in on Thursday and hey it is sorted out ( the RH torsion bar was over adjusted) now it drives straight .Nice to deal with people who actually know wheel alignment and don't just set the Toe.
BABELAAS
2015 Navara 4X4
2015 Navara 4X4
Re: WHEEL ALIGNMENT
jaaaaaaaa??? Babelas -- se nou bikki WAAR het jy di eHB gevat vir sy stuur geite??
