GQ going for service 252 000km
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Next week tuesday my lorrie is going for the 250K service, just picked up the oil and grease seals from Nissan, a whopping R950. Magnatec oil is ready ( I presume a oil filter from a spares shop should be fine? or must one get the Nissan filter?)
I will also change diff oils, want them to bleed clutch and brakes to replace those oils as well. Had gearbox oil replaced at 195K that should still be fine I presume.
How often do you petrol heads change the sparkplugs? and have any of the GQ guys replaced the VALVE STEMS ??
Re: GQ going for service 252 000km
Jules as die valve stemseals nie pla nie los hulle :mytwocents:
rvanrooyen
Full Name: Roland van Rooyen
Nickname: Roland
Home Town: Cape Town, Mamre
Current 4x4: 2000 Nissan Patrol 4.5 GRX
Been thanked: 4 times
Post by rvanrooyen »
Spark plugs can be replace every 30k (more expensive ones every 60k). Sometimes replace at 15k, depending on use of the Patrol.
Jules, I change plugs every service (10k km).
I use GUD or FRAM filters from the spares shops and have never had an issue. Air, oil and petrol.
I presume you mean valve stem seals, not the actual valve stems? Mine are still OK at 270k km. Is your car using oil or smoking when you take your foot off the throttle and coast?
To replace them properly is really a head-off job (doing it with the head on you could in rare cases end up with bent valves) and other than preventing some smoke and some loss of oil, running with worn seals have no other detrimental effects.
Traveler
Full Name: Heinrich Stoltz
Nickname: Traveler
Home Town: Springs
Current 4x4: Patrol 3.0 GL,
Post by Traveler »
Jules, I agree with Peter, rather change the spark plugs every 10k km.
Have you recently replaced the coolant/anti-freeze in the system? It should be replaced every 100,000km.
I would consider "flushing" the sump with a cheaper oil to make sure you get the sludge out the system. Sludge and carbon is an engine killer.
I remember you running on red feul?????
So if that is true change your plugs every service :mytwocents:
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
Jules, wie doen die werk?
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Gerrit ek gaan hom maar weer vir Fanie de Beer gee by Precision Auto, het jy al jou weg oopgesien om saterdag saam te kom ry in Eshowe se heuwels
Current 4x4: None
Jules, op hierdie stadium lyk dit of ek saamgaan :woo: .
Ons moet hierdie maand al die ontwerptekeninge vir twee modelle van die nuwe vragmotors afteken om hulle in produksie te kry en dit gaan maar rof, maar ek gaan my bes probeer om hierdie naweek te ontsnap.
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Terugvoering sover, u-joints moet vervang word by propshaft, linker voor inner wheelbearing ( 33110 soos per PC se artikel ) moet vervang word,Bearing Man R750, Nissan R1599 en toe kry ek een by BOSS Bearing vir R250. Ek is nou net nie seker of die een se "inner corner" ook geskim moet word deur n engineering shop nie want in PC se artikel praat hy van n 35110 wat n standaard size is wat mens moet 'skim'
