Hi guys
I've just about finished with my upholstery mission, but now I've become sidetracked with the odo and clock light that doesn't come on when the light are switched on. I assume that it must be two different lamps or bulbs and because both are dead I assume it is a fuse somewhere. I've checked all the fuses inside the vehicle and they're all fine. The ones under the bonnet is just too confusing? Some are missing and some have higher or lower amp fuses in than it says on the cover. Some of the empty slots could be for something that isn't standard on my model (mine is the GL), but for instance there is one that says Head Light Left and one for Right but when I remove it they still work? Am I missing something? Unfortunately I am obsessive about things that don't work like they should so it is freaking me out!
Any ideas if it is actually a fuse or should I try and replace the lamps? I would definitely prefer the former!
Thanks!
Jonathan
odo/trip meter and clock light
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 193 times
- Been thanked: 275 times
Re: odo/trip meter and clock light
My lights in the centre console (where aircon and so on is) also does not come on, still have to look why
muise het jou draad beetgekry / mices have your wire got hold of / OR a loose connectio or fuse or the globes ahve actually vrekked on you
have you tried looking on the wiring diagram in the manual ???that would be the best !!!!
- jonathan
- Full Name: Jonathan Venter
- Nickname: jonathan
- Home Town: Jacobsbaai
- Current 4x4: 2005 4.8 GRX
- Has thanked: 9 times
- Been thanked: 43 times
I did but it just confused me even more!!!Tinus lotz wrote:have you tried looking on the wiring diagram in the manual ???that would be the best !!!!
- jonathan
Dankie oomie. Ek haat elektriese probleme. Gee my eerder 'n stuk yster met 'n gat in as 'n blerrie spook in die drade! Ek verkies verseker eerder die ratchet bo die multimeterKagiso II wrote:muise het jou draad beetgekry / mices have your wire got hold of / OR a loose connectio or fuse or the globes ahve actually vrekked on you
