FRONT WHEEL BEARING
- Paul
- Full Name: Paul Wiehahn
- Nickname: Intrepid
- Home Town: Malmesbury
- Current 4x4: Nissan Patrol S/W 86 model/Jeep Cherokee Country
- Home Language: Eng/Afr
FRONT WHEEL BEARING
Hi,Any one who can give me the front inner wheel bearing numbers of the cup and cone on a Y60/61---the larger bearing ?I need to fit a 160 front wheel hub onto a Y60 diff---seems like the outer bearing and lock nut are the same.The wheel hub is also the same width.
DO IT WITH YA WHEELS ON DA GROUND
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Re: FRONT WHEEL BEARING
Hi Paul,
I think these are the numbers you are looking for:
For Y60/Y61 front axle:
Inner bearing assembly (the larger one, I think): 43210-C9300
Outer bearing assembly (the smaller one): 40215-C6000
- Gerrit Loubser
- Current 4x4: None
Your welcome, Paul.
Just to confirm what you said in your first post, here are the part numbers for the wheel bearing assemblies on the 160 Series:
Inner bearing assembly: 40210-C6000
Outer bearing assembly: 40215-C6000
So you were right; the outer bearing assemblies of the 16o and Y60/Y61 are the same.
Note that I made a mistake in my first post with the number of the outer bearing assembly, but I corrected it...
- Paul
Much appreciated Gerrit for those bearing sizes.
