Radio Code
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Radio Code
Post by David »
Anybody know where it is recorded?
I attached my CTEK charger to the Trol's battery yesterday and decided to run the recondition program. This stuffed up my radio as I have no idea what the code is :think:
Any help will be appreciated :thumbup:
David
Nickname: David
Re: Radio Code
Post by David »
OK I found it. It is supposed to be in the back of the owners manual but mine isn't - it was in my warrantee booklet. :salute:
Re: Radio Code
I think it is becouse on that cycle it drains the battery flat and then recharges it ???? :think:
David
Nickname: David
Re: Radio Code
Post by David »
Hi Tinus - I dont think it drains the battery because reconditioning happens after the charge cycle. I actually think the CTEK pushed up the voltage and the Troll thought it was under attack and decided to protect itself by shutting down. :rolleyes:
Next time I will rather disconnect the battery when reconditioning :thumbup:
Re: Radio Code
Klink reg !!!ek sal bietjie navorsing doen.....
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Re: Radio Code
Post by Grootseun »
It doest drain the battery flat and also it wasnt because of the higher voltage , when it was reconditioning the battery it first charges it up then drains it at a lower voltage to break up the sulphate and the charges again , probably during this the voltage dropped under 9.8 or so volt and the radio lost its code
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
David
Nickname: David
Re: Radio Code
Post by David »
Dankie Grootseun :clap: I never monitored the voltage but will do so next time to see how low it goes :thumbup:
