Fuel gauge acting funny
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Evening all
Whats makes your fuel gauge (spelling?) go from 1/4 to far below empty and then back to 1/4 while you are driving
Re: Fuel gauge acting funny
earths gravity ???
Bad connectsion on sender unit?
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Post by Grootseun »
Bad earth on instument cluster , bad connection on the sender untit or bad voltage regulator in the gauge itself - veryy common fault on the older Toy's
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Ek het 'n rukkie terug 'n soortgelyke probleem gehad. Die brandstof meter het tussen vol en 1/4 gefluktueer, nogal kommerwekkend. Dit het hard gereën. Na dit droog geword het, het die probleem verdwyn. Moontlik het die nattigheid dit in my geval veroorsaak.
Sorted Jules ??
Shalom bru .. sala kahle..
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Feedback
Die auto elektrisien het al die drade ens nagegaan, geen probleem, hy reken die probleem is dalk in die tenk
shalom
