the correct tipe of battery for your camping needs
http://www.deltecpower.co.za/content/lead-crystal
read this and look at the specks
it charges the same or faster as a crank battery
it can get hot and not brake
it can be stored for up to 2 years with no damige
doensnt mind to be shaken around on dirt roads ect
does not need maintance and life span is great!!!! :thumbup:
I have been looking at this for a long time and this tipe of battery makes sence for overlanding :blonde:
this battery is not for cranking your diesel but perfect for your frige ect.
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Re: the correct tipe of battery for your camping needs
Post by Jules »
"it can get hot and not brake"
Tinus please verduidelik 4 oom Jules wat you means by that comment ??? :think:
When a normal d s battery goes over 45. Deg it loses life and does not charge becouse the elecrtolite starts failing
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
O ok , me gedog it helps the Patrol to brake for the potholes :rolling:
Jules, focus now!
It's a Patrol, it doesn't care about potholes!
Sorry jules die bberry maak maar so as hy check dit moet break wees
:rolling:
Dis natuurlik hoekom dit beter is om die battery agter in die Patrol te sit as onder die enginkap.
Tunja
Full Name: Ernest Tunnah
Nickname: Tunja
Home Town: Swakopmund
Has thanked: 9 times
Been thanked: 18 times
Post by Tunja »
Peter Connan wrote:Jules, focus now!
Err, haven't felt or seen any of those since I got the Troll :lol:
Peter
Gaan kyk in Delareyville se hoofstraat, Dit is erger as van Zylspas.
