Safari Diff required
- Paul
- Full Name: Paul Wiehahn
- Nickname: Intrepid
- Home Town: Malmesbury
- Current 4x4: Nissan Patrol S/W 86 model/Jeep Cherokee Country
- Home Language: Eng/Afr
Anyone out there in the Cape wanting to sell a Safari/Patrol front diff.I need the casing which has not bent yet.That's for the leaf sprung models.STANGE,mine don't last too long
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
- Engel
- Full Name: Herman Engelbrecht
- Nickname: Engel
- Home Town: Kempton park
- Current 4x4: MQ patrol
Gu Patrol
Triton - Home Language: maakiesaakie
- Been thanked: 1 time
Re: Safari Diff required
i will help looking for one. Those thing are strong so I would not ask how you did it. When you get a new one, just reinforce it
Herman 0824453301
herman@angeloffroad.co.za
YO !!! Paul - you are supposed to DRIVE the Safari .. not DROP it from ariroplanes & H copters ... makie skaie HOEVEEL daai ouens jou vir die 'ad' betaal nie .. daai as sal maar buig.
ernstig - laat die 'chassis' met i/r nagaan vir gebuig of erger - ge 'twist'
- my rede is OUDERDOM --- wat is JOU verskoning ??
- Paul
Ja....,dis maar my eige skuld.Ek sit nou al my sesde diff cassing nou in en het al seker so vier keer reg gebuig.
Mo#rse werk elke keer.Aanvanklik het ek gedink die staal tubes buig--dis 10mm wanddikte.Toe gedink dit is by die vernouing
Wat wel gebeur ,is dat die gegote yster housing aan die onderkant rek of oopkraak,want onder die ou lorrie se kap sit daar 'n Fairmont GT 351 met 'n FMX auto wat met die gegote yster transfer box getroud is.Swaaaar!!
DO IT WITH YA WHEELS ON DA GROUND
Invert jou voorvere en sit 'n "slip joint" in die voorste propshaft
- Paul
Ek het 'n prop met 'n slip joint alreeds in,maar vertel my van die vere se inversion?
Daar is vyf vere per pak met taamlike kurwe.
- Theuhan
- Full Name: Theuhan
- Nickname: theuhan
- Home Town: Roodepoort
- Current 4x4: 1982 Datsun Safari
1992 gq Patrol SWB - Home Language: Afrikaans
- Been thanked: 3 times
Jong ek ry my trok hard maar dit is die eerste keer dat ek van dit hoor, het jy enige video's op Youtube dat ons kan gaan kyk hoe jy ry.
82 Safari SOA
92 Patrol SWB
92 Patrol SWB
- Paul
Hallo Theuhan,
As ek nou goed op Utube moet plaas,gaan hulle omidelik dit verban.Dit sal so 'n slegte invloed op die groeiende 4x4 drywers afvryf.
So ja,'n man probeer om jou wiele so veel moontlik teen moederaarde in kontak hou.
Yo Paul - askies - ik kom maar min hier - nie gesien jy vra oor die "inversion" nie - dit beteken jy draai die veerpak om en swop ... en jy skuif die ankerpunt [wat nou agter sit, na voor die as ] M A W - maak dit dieselfde as op jou agteras [agggggg bedoel die Safari se agteras...]
Dan kan jy ook langer shackles insit - ek dink ???
