Replacing the factory Arial - How?
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Hi guys, on my pickup i have a factory fitted whip arial on the left front panel (just in front of the windscreen next to the bonnet.) I need to replace mine as it broke of at the plastic base when a tree caught it.
Problem is, i cant see any way of getting in there to loosen the thing without taking the entire panel off? surely this cant be right?
Advice please?
Russ
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Re: Replacing the factory Arial - How?
Post by Grootseun »
Try removing the inner fender liner , sometime you get lucky
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Aries66
Full Name: Louis Naude
Nickname: Aries66
2011 Navara 3.0V6 V9X
Post by Aries66 »
Hi Russ
Yes i recently replaced mine. Just remove the plastic inner cover and you have access to the antenna.
Russ Kellermann
Ok kewl! Gonna try that.
Russ Kellermann
Didn't work.
Had to take the entire fkn pannel off the side which meant undoing headlights and all sorts of other stuff, absolutely pathetic design. Took hours and hours to change a bloody arial.
I cannot believe that in the modern world a company as established as Nissan would design a vehicle where one has to literally take the side of the car off to change a peripheral device. :thumbdown:
Has thanked: 1136 times
Been thanked: 1047 times
Russ, that kind of thing is only getting worse.
On the Landy Disco 3 and 4 I am told you need to remove the whole body in order te replace the timing belt (not sure if this is true for all engines or only the Diesels)!
Grootseun
Nickname: Grootseun
Post by Grootseun »
Peter , thats true on the diesels , that muvh i know as we had to do that a clients workshop the other day
Russ , thats a pity on the older Nissans you jsut worked through the inner fender space
Now im even gladder that when my trolls electric antenna went i fittted the internal stick on version that sits behind the rear view mirror on the windscreen and it only cost me R50 and works sweet i must add
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
I got one of those stick on ones too.... but now my radio reception is almost non existent !!!..... Paid a lot more than R50 for mine too...... The dude says its cause my radio is old and he must put a frequency modulator in ....or something like that
Grootseun
Nickname: Grootseun
Post by Grootseun »
Cedric , i run a oldish sony frontloader and honeslty have no reception issues we need to look at what your running , mine was R50 from Midas and plugs straight into the radio and has one power lead , and no problems yet , check your earth cable to your radio , ive found many radios with bad earth trying to earth through the areail and then no radio reception
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 29 times
Been thanked: 136 times
Post by ChristoSlang »
I also replaced my original Nissan aerial with a R50 rubber "bee-sting" from Midas, and it works like a charm. I sommer bought two of them so that have a spare in case the first goes missing. It's short enough not to catch on branches, can unscrew when I really want it out of the way, and the reception is perfect. Nissan thought that R2500 for a new aerial was a fair price - I just don't understand their thinking at all :think:
In my case it was sufficient to remove the wheel liner only. It was a tough job fastening the replacement properly, as space very limited in there. Some threatening language seemed to help with the process! :lol:
Christo (the snake man)
