Nissan Patrol Steering Damper for Sale
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
I have a brand new Patrol steering damper for sale for R600.
Wilfred bought it for me in UAE on his last trip - but does not fit the 4.8.
I know it fits the 3L Short wheel base, but not sure what other model it fits.
The reason it does not fit the 4.8 is that the bolt attachments at the ends do not do not extend linearly ie in one straight line as they normally do.
This damper has the bolt attachment at 90 degrees to the longitudinal direction of the damper.
The label on the package reads:
Nissan Genuine Part
Damper-Steering
48611-VC000
I can not attach a photo as the site does not accept uploads currently -
Please contact me if you are interested. I will email you photo if needed.
Re: Nissan Patrol Steering Damper for Sale
i also need one for 4.8 were did you get one or are you going to use tjm or ome????
Lots of reports on this forum that the aftermarket ones do not last as long as Nissan part Tinus
Chris Skinner
Nickname: Chris
Tinus, I have not yet changed the damper on my vehicle. I removed the old one before the new one arrived, and when I saw it was wrong part I put the old one back. Its condition was better than I expected.
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Post by Grootseun »
Chris ill check how the bolts on my 3.0 looks if they are the same your diagnostic shop will be taking it as mine has 255 000km on already
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Chris Skinner
Nickname: Chris
Let me know, I will drop off tomorrow with my winch.
Been thanked: 473 times
Hmmmm.... would it fit the '99 - 4.2 diesel, or is the damper the same as on the 4,8???
Chris Skinner
Nickname: Chris
Ricter, check your damper and see where the item bolts onto the steering parts. If the bolts are in straight line with the axis of the damper then it will not fit.
The only vehicle so far identified to take this damper with the bolts at 90 degrees is the short wheel base.
The item is still available though at very good price - so, guys check your dampers....it will be a waste to send this back to UAE if it could be of use to someone here in ZA.
I'll check tonight !!
Chris Skinner
Nickname: Chris
Heres a pic of the new steering damper I have for sale - I am really interested to know which model it fits...
2012-02-15 09.37.59.jpg (111.51 KiB) Viewed 3209 times
note the attachment bolts different from 4.8/4.5
2012-02-15 09.37.52.jpg (103.05 KiB) Viewed 3209 times
